Database location
Good morning,
As part of the industrialization of my processes, I would like to automate the creation of flows in node red.
To be more precise, I want to have an SD card with a basic stream that would allow me to make a copy from a specific file containing a JSON node red.
Can I do an import flow directly through a node? if not can I tell node red to make a copy and paste in the nodered source folder where the flows are located. and then a restart? if so where is the folder containing the flows located?
You can use the admin api to post a flow Admin API Methods : Node-RED
Great! but flows.write authorization is required. How can I activate this? I can't find the information on the site.
I don't have identification on my node-red
I tried another approach via postman.
now i have an error
"code": "unexpected_error",
"message": "config.forEach is not a function"
with body :
"id": "91ad451.f6e52b8",
"label": "test",
"nodes": [{"id":"b26325bc.6122d8","type":"tab","label":"Sywa","disabled":false,"info":""},{"id":"81f4e74d.24eee8","type":"http request","z":"b26325bc.6122d8","name":"","method":"POST","ret":"obj","paytoqs":"ignore","url":"","tls":"","persist":false,"proxy":"","authType":"","x":470,"y":220,"wires":[["5076216b.6ecc8"]]},{"id":"ef9709bf.b95f18","type":"change","z":"b26325bc.6122d8","name":"","rules":[{"t":"set","p":"headers","pt":"msg","to":"{}","tot":"json"},{"t":"set","p":"headers.Content-Type","pt":"msg","to":"application/x-www-form-urlencoded","tot":"str"},{"t":"set","p":"payload","pt":"msg","to":"client_id=web_app&username=accesscontrol@sywa.fr&password=Accesscontrol1!&grant_type=password","tot":"str"},{"t":"set","p":"url","pt":"msg","to":"https://auth.app.sywa.fr/auth/realms/sywa-preprod/protocol/openid-connect/token","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":300,"y":220,"wires":[["81f4e74d.24eee8"]]},{"id":"79c194a9.a950ec","type":"inject","z":"b26325bc.6122d8","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":130,"y":220,"wires":[["ef9709bf.b95f18","8094763.a62db88"]]},{"id":"5076216b.6ecc8","type":"change","z":"b26325bc.6122d8","name":"","rules":[{"t":"set","p":"token","pt":"global","to":"payload.access_token","tot":"msg"},{"t":"set","p":"token","pt":"msg","to":"token","tot":"global"},{"t":"set","p":"headers","pt":"msg","to":"{}","tot":"json"},{"t":"set","p":"headers.Authorization","pt":"msg","to":"\"Bearer " & $$.token","tot":"jsonata"},{"t":"set","p":"headers.Accept","pt":"msg","to":"application/json","tot":"str"},{"t":"set","p":"url","pt":"msg","to":"https://api.preprod.sywa.fr/access-controls/2/attendees","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":640,"y":220,"wires":[["bc23a03b.fa0a8"]]},{"id":"bc23a03b.fa0a8","type":"http request","z":"b26325bc.6122d8","name":"","method":"GET","ret":"obj","paytoqs":"ignore","url":"","tls":"","persist":false,"proxy":"","authType":"","x":810,"y":220,"wires":[["6a0d7785.a576a8"]]},{"id":"6a0d7785.a576a8","type":"split","z":"b26325bc.6122d8","name":"","splt":"\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"","x":950,"y":220,"wires":[["7e7bf58f.ecfd1c","ba414ab7.ea59e8"]]},{"id":"ee3ecafb.5dddf8","type":"debug","z":"b26325bc.6122d8","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":590,"y":280,"wires":},{"id":"8094763.a62db88","type":"function","z":"b26325bc.6122d8","name":"DELETE ","func":"var newMsg = {\n"topic" : "DELETE FROM access_valid WHERE 1"\n}\nreturn newMsg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":,"x":280,"y":280,"wires":[["7f94c7eb.f4d0c8"]]},{"id":"3f5e09ad.eada76","type":"Stackhero-MySQL","z":"b26325bc.6122d8","server":"6e6c4c1b.6c0d54","name":"","x":1250,"y":220,"wires":[]},{"id":"7f94c7eb.f4d0c8","type":"Stackhero-MySQL","z":"b26325bc.6122d8","server":"6e6c4c1b.6c0d54","name":"","x":430,"y":280,"wires":[["ee3ecafb.5dddf8"]]},{"id":"7e7bf58f.ecfd1c","type":"change","z":"b26325bc.6122d8","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":""INSERT INTO access_valid(Id,lastName, firstName, projectStatus, projectName, projectdateEnd, projectdateStart, employerName) VALUES ('"&payload.id&"','"&payload.lastName&"','"&payload.firstName&"','"&payload.project.status&"','"&payload.project.name&"','"&payload.project.dateEnd&"','"&payload.project.dateStart&"','"&payload.employer.name&"')"","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":1090,"y":220,"wires":[["3f5e09ad.eada76"]]},{"id":"ba414ab7.ea59e8","type":"debug","z":"b26325bc.6122d8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1220,"y":120,"wires":},{"id":"6e6c4c1b.6c0d54","type":"Stackhero-MySQL-Server","name":"","host":"localhost","port":"3306","tls":false,"database":"accesssite"}]
Thanks for your help
I have this error but i don't have the solution .
    "message": "invalid node type: tab"
The flow you posted is corrupt, use the </> button when posting code.
Also show us what you have tried.
Are you trying to post that to the admin api, via postman, or what?
  "id": "8",
  "label": "test",
  "nodes": [{"id":"84e74d.24eee8","type":"http request","z":"b26325bc.6122d8","name":"","method":"POST","ret":"obj","paytoqs":"ignore","url":"","tls":"","persist":false,"proxy":"","authType":"","x":470,"y":220,"wires":[["5076216b.6ecc8"]]},{"id":"ef9709bf.b95f18","type":"change","z":"b26325bc.6122d8","name":"","rules":[{"t":"set","p":"headers","pt":"msg","to":"{}","tot":"json"},{"t":"set","p":"headers.Content-Type","pt":"msg","to":"application/x-www-form-urlencoded","tot":"str"},{"t":"set","p":"payload","pt":"msg","to":"client_id=web_app&username=accesscontrol@sywa.fr&password=Accesscontrol1!&grant_type=password","tot":"str"},{"t":"set","p":"url","pt":"msg","to":"https://auth.app.sywa.fr/auth/realms/sywa-preprod/protocol/openid-connect/token","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":300,"y":220,"wires":[["81f4e74d.24eee8"]]},{"id":"79c194a9.a950ec","type":"inject","z":"b26325bc.6122d8","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":130,"y":220,"wires":[["ef9709bf.b95f18","8094763.a62db88"]]},{"id":"5076216b.6ecc8","type":"change","z":"b26325bc.6122d8","name":"","rules":[{"t":"set","p":"token","pt":"global","to":"payload.access_token","tot":"msg"},{"t":"set","p":"token","pt":"msg","to":"token","tot":"global"},{"t":"set","p":"headers","pt":"msg","to":"{}","tot":"json"},{"t":"set","p":"headers.Authorization","pt":"msg","to":"\"Bearer \" & $$.token","tot":"jsonata"},{"t":"set","p":"headers.Accept","pt":"msg","to":"application/json","tot":"str"},{"t":"set","p":"url","pt":"msg","to":"https://api.preprod.sywa.fr/access-controls/2/attendees","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":640,"y":220,"wires":[["bc23a03b.fa0a8"]]},{"id":"bc23a03b.fa0a8","type":"http request","z":"b26325bc.6122d8","name":"","method":"GET","ret":"obj","paytoqs":"ignore","url":"","tls":"","persist":false,"proxy":"","authType":"","x":810,"y":220,"wires":[["6a0d7785.a576a8"]]},{"id":"6a0d7785.a576a8","type":"split","z":"b26325bc.6122d8","name":"","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"","x":950,"y":220,"wires":[["7e7bf58f.ecfd1c","ba414ab7.ea59e8"]]},{"id":"ee3ecafb.5dddf8","type":"debug","z":"b26325bc.6122d8","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":590,"y":280,"wires":[]},{"id":"8094763.a62db88","type":"function","z":"b26325bc.6122d8","name":"DELETE ","func":"var newMsg = {\n\"topic\" : \"DELETE FROM `access_valid` WHERE 1\"\n}\nreturn newMsg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":280,"y":280,"wires":[["7f94c7eb.f4d0c8"]]},{"id":"3f5e09ad.eada76","type":"Stackhero-MySQL","z":"b26325bc.6122d8","server":"6e6c4c1b.6c0d54","name":"","x":1250,"y":220,"wires":[[]]},{"id":"7f94c7eb.f4d0c8","type":"Stackhero-MySQL","z":"b26325bc.6122d8","server":"6e6c4c1b.6c0d54","name":"","x":430,"y":280,"wires":[["ee3ecafb.5dddf8"]]},{"id":"7e7bf58f.ecfd1c","type":"change","z":"b26325bc.6122d8","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"\"INSERT INTO `access_valid`(`Id`,`lastName`, `firstName`, `projectStatus`, `projectName`, `projectdateEnd`, `projectdateStart`, `employerName`) VALUES ('\"&payload.id&\"','\"&payload.lastName&\"','\"&payload.firstName&\"','\"&payload.project.status&\"','\"&payload.project.name&\"','\"&payload.project.dateEnd&\"','\"&payload.project.dateStart&\"','\"&payload.employer.name&\"')\"","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":1090,"y":220,"wires":[["3f5e09ad.eada76"]]},{"id":"ba414ab7.ea59e8","type":"debug","z":"b26325bc.6122d8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1220,"y":120,"wires":[]},{"id":"6e6c4c1b.6c0d54","type":"Stackhero-MySQL-Server","name":"","host":"localhost","port":"3306","tls":false,"database":"accesssite"}]
I use postman but now i have a new error message. Knowing that if I import this json from node red I have no problem.
    "message": "duplicate id"
methodology :
  • I made the flow via node red
  • deploy to test this was good
once validated:
  • I selected the nodes to export and retrieve the json
  • I deleted the flow and redeployed
  • now I try to create a new flow with the copy of the node red export
the final goal being that the action is done directly via node-red and not postman but for the moment it allows me to do my tests and to have the error messages
The code you have posted is not a valid flow for importing.
Try to import into the editor and you will see.
