deploying/Importing without pressing deploy/import
Hello, I have created a flow that is able to output an importable json object, which creates it's own flow, this is based on "https://eightbar.eu-gb.mybluemix.net/2014/01/19/node-red-flows-that-make-flows/"
My next step is to import and deploy the new flow automatically, meaning that if press inject it will do everything else. Is this possible? Any help would be really useful, I can include my flow if it would help. Thank you
[{"id":"78d9148.cd85bec","type":"function","z":"4fbdfc79.a0e3d4","name":"\"Kafka Consumer Group\"","func":"// create the parameters object from the incoming JSON object\nmsg.payload.push({\"id\":\"9d62194.66f19e8\",\ntype:\"Kafka Consumer Group\",\nz:\"44b6e5c1.60373c\",\nname:\"\",\nbroker:\"f4c7e5bd.09b818\",\ngroupId:\"eGroup\",\nsessionTimeout:15000,\nprotocol:[\"roundrobin\"],\nencoding:\"utf8\",\nfromOffset:\"latest\",\ncommitOffsetsOnFirstJoin:\"true\",\noutOfRangeOffset:\"earliest\",\ntopics:[msg.flow],\nx:140,\ny:200,\nwires:[[\"cbde2001.30002\"]]});\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":830,"y":300,"wires":[["726314e2.9379dc"]]},{"id":"435f421b.24853c","type":"function","z":"4fbdfc79.a0e3d4","name":"initialise","func":"// create the parameters object from the incoming JSON object\nconsole.log(msg.payload);\n//msg.parameters = JSON.parse(msg.payload);\n\n// we're going to create an array of objects\nmsg.payload = [];\nmsg.id = 0;\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":580,"y":300,"wires":[["78d9148.cd85bec"]]},{"id":"8211ab8e.04a3a8","type":"inject","z":"4fbdfc79.a0e3d4","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{\"first\":\"busStop\", \"second\":\"json\"}","payloadType":"str","x":470,"y":200,"wires":[["4c0ca569.dc19cc"]]},{"id":"81705080.fc42d","type":"debug","z":"4fbdfc79.a0e3d4","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":630,"y":540,"wires":[]},{"id":"726314e2.9379dc","type":"function","z":"4fbdfc79.a0e3d4","name":"json","func":"msg.payload.push({\nid:\"cbde2001.30002\",\ntype:\"json\",\nz:\"44b6e5c1.60373c\",\nname:\"\",\nproperty:\"payload\",\naction:\"\",\npretty:false,\nx:330,\ny:200,\nwires:[[\"8b5a275.4eb6fd8\"]]});\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":1090,"y":300,"wires":[["5ec7955c.4a89bc"]]},{"id":"5ec7955c.4a89bc","type":"function","z":"4fbdfc79.a0e3d4","name":"trigger","func":"msg.payload.push({\nid:\"58100134.d8b32\",\ntype:\"trigger\",\nz:\"44b6e5c1.60373c\",\nname:\"Error after 10 minutes\",\nop1:\"1\",\nop2:\"0\",\nop1type:\"str\",\nop2type:\"str\",\nduration:\"10\",\nextend:true,\noverrideDelay:false,\nunits:\"min\",\nreset:\"\",\nbytopic:\"all\",\ntopic:\"topic\",\noutputs:2,\nx:780,\ny:280,\nwires:[[],[\"64dd72c.0131f8c\"]]});\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":1250,"y":300,"wires":[["6423dc91.aa72f4"]]},{"id":"6423dc91.aa72f4","type":"function","z":"4fbdfc79.a0e3d4","name":"change: payload to OFF","func":"msg.payload.push({\nid:\"64dd72c.0131f8c\",\ntype:\"change\",\nz:\"44b6e5c1.60373c\",\nname:\"\",\nrules:[{\"t\":\"set\",\"p\":\"payload\",\"pt\":\"msg\",\"to\":\"OFF\",\"tot\":\"str\"}],\naction:\"\",\nproperty:\"\",\nfrom:\"\",\nto:\"\",\nreg:false,\nx:1060,\ny:300,\nwires:[[\"454be8.c787a418\"]]});\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":1430,"y":300,"wires":[["735da494.0082bc"]]},{"id":"735da494.0082bc","type":"function","z":"4fbdfc79.a0e3d4","name":"change: payload to ON","func":"msg.payload.push({\nid:\"800b91bd.2cc58\",\ntype:\"change\",\nz:\"44b6e5c1.60373c\",\nname:\"\",\nrules:[{\"t\":\"set\",\"p\":\"payload\",pt:\"msg\",to:\"ON\",\"tot\":\"str\"}],\naction:\"\",\nproperty:\"\",\nfrom:\"\",\nto:\"\",\nreg:false,\nx:760,\ny:360,\nwires:[[\"73ad45ec.62d3ac\"]]});\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":300,"y":360,"wires":[["132e1409.8da13c"]]},{"id":"132e1409.8da13c","type":"function","z":"4fbdfc79.a0e3d4","name":"function","func":"msg.payload.push({\nid:\"73ad45ec.62d3ac\",\ntype:\"function\",\nz:\"44b6e5c1.60373c\",\nname:\"Test\",\nfunc:\"msg.color = (msg.payload === \\\"ON\\\")?\\\"lime\\\":\\\"red\\\";\\nreturn msg;\",\noutputs:1,\nnoerr:0,\"initialize\":\"\",\nfinalize:\"\",\nx:1010,\ny:360,\nwires:[[\"454be8.c787a418\"]]});\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":520,"y":360,"wires":[["65683c0a.d21114"]]},{"id":"65683c0a.d21114","type":"function","z":"4fbdfc79.a0e3d4","name":"ui_text: Working test","func":"msg.payload.push({\nid:\"454be8.c787a418\",\ntype:\"ui_text\",\nz:\"44b6e5c1.60373c\",\ngroup:msg.flow,\norder:3,\nwidth:\"3\",\nheight:\"3\",\nname:\"Working test\",\nlabel:\"Message recieved within last 10 minutes?\",\nformat:\"<font color={{msg.color}} ><i class=\\\"fa fa-circle\\\" style=\\\"font-size:48px;\\\"></i></font>\",\nlayout:\"row-center\",\nx:1230,\ny:360,\nwires:[]});\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":760,"y":360,"wires":[["b0ed818d.a637e"]]},{"id":"b0ed818d.a637e","type":"function","z":"4fbdfc79.a0e3d4","name":"counter","func":"msg.payload.push({\nid:\"32db4683.3407aa\",\ntype:\"counter\",\nz:\"44b6e5c1.60373c\",\nname:\"\",\ninit:\"0\",\nstep:\"1\",\nlower:\"\",\nupper:\"\",\nmode:\"increment\",\noutputs:\"1\",\nx:720,\ny:460,\nwires:[[\"480ba7e.d806b58\",\"10183839.4a3418\",\"83b37196.856a\",\"6725370d.b391c8\"]]});\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":960,"y":360,"wires":[["4327932e.0160ec"]]},{"id":"4327932e.0160ec","type":"function","z":"4fbdfc79.a0e3d4","name":"change: Delete paylolad","func":"msg.payload.push({\nid:\"8b5a275.4eb6fd8\",\ntype:\"change\",\nz:\"44b6e5c1.60373c\",\nname:\"Delete paylolad\",\nrules:[{\"t\":\"delete\",\np:\"payload\",\npt:\"msg\"}],\naction:\"\",\nproperty:\"\",\nfrom:\"\",\nto:\"\",\nreg:false,\nx:500,\ny:240,\nwires:[[\"800b91bd.2cc58\",\"58100134.d8b32\",\"32db4683.3407aa\"]]});\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":1190,"y":360,"wires":[["aea61abb.2a3db8"]]},{"id":"aea61abb.2a3db8","type":"function","z":"4fbdfc79.a0e3d4","name":"trigger: Message stopped","func":"msg.payload.push({\nid:\"480ba7e.d806b58\",\ntype:\"trigger\",\nz:\"44b6e5c1.60373c\",\nname:\"Message stopped\",\nop1:\"\",\nop2:\"0\",\nop1type:\"nul\",\nop2type:\"str\",\nduration:\"1\",\nextend:true,\noverrideDelay:false,\nunits:\"min\",\nreset:\"\",\nbytopic:\"all\",\ntopic:\"topic\",\noutputs:1,\nx:970,\ny:420,\nwires:[[\"e30629ef.5a3d98\"]]});\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":1430,"y":360,"wires":[["b4e296b3.11f0f8"]]},{"id":"b4e296b3.11f0f8","type":"function","z":"4fbdfc79.a0e3d4","name":"ui_text: Total messages","func":"msg.payload.push({\nid:\"10183839.4a3418\",\ntype:\"ui_text\",\nz:\"44b6e5c1.60373c\",\ngroup:msg.flow,\norder:1,\nwidth:0,\nheight:0,\nname:\"Total messages\",\nlabel:\"Total messages:\",\nformat:\"{{msg.count}}\",\nlayout:\"row-spread\",\nx:1260,\ny:520,\nwires:[]});\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":310,"y":440,"wires":[["e84ca2a.721186"]]},{"id":"e84ca2a.721186","type":"function","z":"4fbdfc79.a0e3d4","name":"file","func":"msg.payload.push({\nid:\"e30629ef.5a3d98\",\ntype:\"file\",\nz:\"44b6e5c1.60373c\",\nname:\"\",\nfilename:\"count\",\nappendNewline:true,\ncreateDir:false,\noverwriteFile:\"true\",\nencoding:\"none\",\nx:1270,\ny:420,\nwires:[[]]});\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":510,"y":440,"wires":[["c18c90f8.13962"]]},{"id":"c18c90f8.13962","type":"function","z":"4fbdfc79.a0e3d4","name":"ui_text: Current messages","func":"msg.payload.push({\n\"id\":\"abb1f2b1.b383b\",\n\"type\":\"ui_text\",\n\"z\":\"44b6e5c1.60373c\",\n\"group\":msg.flow,\n\"order\":1,\n\"width\":0,\n\"height\":0,\n\"name\":\"Current messages\",\n\"label\":\"Current messages:\",\n\"format\":\"{{msg.count}}\",\n\"layout\":\"row-spread\",\n\"x\":1490,\n\"y\":580,\n\"wires\":[]});\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":730,"y":440,"wires":[["90fef8d.0695d08"]]},{"id":"90fef8d.0695d08","type":"function","z":"4fbdfc79.a0e3d4","name":"trigger","func":"msg.payload.push({\nid:\"83b37196.856a\",\ntype:\"trigger\",\nz:\"44b6e5c1.60373c\",\nname:\"Message stopped\",\nop1:\"\",\nop2:\"0\",\nop1type:\"nul\",\nop2type:\"str\",\nduration:\"1\",\nextend:true,\noverrideDelay:false,\nunits:\"min\",\nreset:\"\",\nbytopic:\"all\",\ntopic:\"topic\",\noutputs:1,\nx:930,\ny:620,\nwires:[[\"586eece1.8088d4\"]]});\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":930,"y":440,"wires":[["73df2b77.448164"]]},{"id":"73df2b77.448164","type":"function","z":"4fbdfc79.a0e3d4","name":"change:set msg.reset to true","func":"msg.payload.push({\nid:\"586eece1.8088d4\",\ntype:\"change\",\nz:\"44b6e5c1.60373c\",\nname:\"Reset\",\nrules:[{\"t\":\"set\",\"p\":\"reset\",\"pt\":\"msg\",\"to\":\"true\",\"tot\":\"str\"}],\naction:\"\",\nproperty:\"\",\nfrom:\"\",\nto:\"\",\nreg:false,\nx:1090,\ny:620,\nwires:[[\"6725370d.b391c8\"]]});\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":1140,"y":440,"wires":[["99799dc7.b94ef"]]},{"id":"99799dc7.b94ef","type":"function","z":"4fbdfc79.a0e3d4","name":"counter","func":"msg.payload.push({\nid:\"6725370d.b391c8\",\ntype:\"counter\",\nz:\"44b6e5c1.60373c\",\nname:\"\",\ninit:\"0\",\nstep:\"1\",\nlower:\"\",\nupper:\"\",\nmode:\"increment\",\noutputs:\"1\",\nx:1240,\ny:580,\nwires:[[\"abb1f2b1.b383b\"]]});\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":1340,"y":440,"wires":[["4dfd954f.68af7c"]]},{"id":"4dfd954f.68af7c","type":"function","z":"4fbdfc79.a0e3d4","name":"Kafka Broker","func":"msg.payload.push({\nid:\"f4c7e5bd.09b818\",\ntype:\"Kafka Broker\",\nname:\"\",\nhosts:[{\"host\":\"kafka\",\"port\":9092}],\nhostsEnvVar:\"\",\nconnectTimeout:\"10000\",\nrequestTimeout:\"30000\",\nautoConnect:\"true\",\nidleConnection:\"5\",\nreconnectOnIdle:\"true\",\nmaxAsyncRequests:\"10\",\ncheckInterval:\"10\",\nselfSign:true,\nusetls:false,\nuseCredentials:false});\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":1490,"y":440,"wires":[["98f15499.517b28"]]},{"id":"98f15499.517b28","type":"function","z":"4fbdfc79.a0e3d4","name":"ui_group:busStop","func":"msg.payload.push({\n\"id\":msg.flow,\n\"type\":\"ui_group\",\n\"name\":msg.flow,\n\"tab\":\"a65b3274.2fafb\",\n\"order\":1,\n\"disp\":true,\n\"width\":\"6\",\n\"collapse\":false});\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":290,"y":540,"wires":[["842cbca2.bc02e"]]},{"id":"842cbca2.bc02e","type":"function","z":"4fbdfc79.a0e3d4","name":"ui_tab","func":"msg.payload.push({\nid:msg.flow,\ntype:\"ui_tab\",\nname:msg.flow,\nicon:\"dashboard\",\ndisabled:false,\nhidden:false});\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":470,"y":540,"wires":[["81705080.fc42d"]]},{"id":"4c0ca569.dc19cc","type":"file in","z":"4fbdfc79.a0e3d4","name":"","filename":"autocompose.yaml","format":"utf8","chunk":false,"sendError":false,"encoding":"none","x":710,"y":200,"wires":[["36798317.530d8c"]]},{"id":"36798317.530d8c","type":"python-function","z":"4fbdfc79.a0e3d4","name":"","func":"count = 0\nmsgcount = 0\nlines = []\nwith open(\"autocompose.yaml\") as fp: \n\tfor line in fp: \n\t\tcount += 1\n\t\tcurline = line.strip()\n\t\tif(curline.startswith(\"- KAFKA_TOPIC_OUT=\")):\n\t\t    newline = curline[18: ]\n\t\t    lines.append(newline)\n\t\t    msgcount += 1\nmsg['payload'] = lines\nreturn msg \n","outputs":1,"x":940,"y":200,"wires":[["a0b0e9b5.eb3508"]]},{"id":"a0b0e9b5.eb3508","type":"split","z":"4fbdfc79.a0e3d4","name":"","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"","x":230,"y":300,"wires":[["8c6f9f44.b79b5"]]},{"id":"8c6f9f44.b79b5","type":"change","z":"4fbdfc79.a0e3d4","name":"","rules":[{"t":"set","p":"flow","pt":"msg","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":390,"y":300,"wires":[["435f421b.24853c"]]}]
I doubt if you want that.
Sounds like a very handy function for virus builders etc..to take over control.
Thank you for the advice, but what I am hoping to create would read a single file and create a flows based on that file, it wouldn't be given to the public so if they wanted to abuse it they would have already had to get into the servers by that point.
I believe the node-red admin api has capabilities that will do what you want, or at least some of it.
Hello, sorry I didn't notice the notification for your message. Is there a good place to learn how to use the API? I have had a look at it and am unsure how it work. Thank you
Have you read the documentation? https://nodered.org/docs/api/
Yes, I just had a look at the API and someone explained it to me, I think I understand it now. Thank you for all the help :slight_smile:
