Debug node name is not displayed in debug sidebar if debug node is used in a subflow even it is named correctly
I am using 1.0.0.
I found that if I put a debug node inside a subflow with a name, the node name is not displayed in the debug sidebar, instead nodeid is displayed.
I am not using 1.0.0 yet.
But doing a quick search, I can't see/find where it says it does support debug nodes.
But if you are saying you are seeing debug output, I'm sorry: I can't help.
I was only wanting to say I can't find where it says it supports debug output.
I beleive that is because the subflow can be used in many flows so a unique ID is given to each occurrence. If it only displayed the name of the debug node, how would you tell which occurance it was refering to?
While I agree and understand, what's the harm in displaying "parent.name"? Or even "name" so long as clicking the id takes you to the correct instance? :thinking:
