As subject, I have 1 debug node that produces output while it's muted, how is this possible ?
Happens to the best of us....
When it happens to me (on occasions), I toggle the debug node "on and off" and redeploy and all is well again
Why it happens? That is above my pay grade.
are you sure it's not from another flow?
not from another flow: 100%
Still, when looking into these things, you should select Current Flow as @ghayne mentioned, as your screen grabby shows All Nodes ...
I can reproduce like this, but
- Now enable the debug output,
I always deploy when i see the lovely red button.
It must have been something in this direction.
Change to current flow and try again ....
Already known issue - https://github.com/node-red/node-red/issues/2432
@unixneo - look at the node id number and compare to the debug output i posted in the first post: same number, same debug node.
As I mentioned earlier....
Frankly, it's not a big deal and so I don't worry about it.....(bigger fish to fry.... )
It is a known bug as mentioned above.
I have from the start, and still think, it is ridiculous that the deploy button gets activated just because I toggle the debug node button, typical engineering not matching common sense
It is kind of weird, but I can imagine it is required in order to save the flow state by following the existing internal runtime functions, else, i suspect, it should follow a separate path internally, introduces other problems. Just a wild guess.
@bakman2 that known issue is specifically related to Ctrl-Z not undoing the disabled state on the runtime side. Is that what you did?
If not, then this is a different issue.
@knolleary I can't reproduce my specific behaviour, I can replicate what @krambriw suggested. Will wait for reoccurance (and reproduction)
