I'm encountering an issue where the functions inside ui_base.js are not being called, even though the init function is executed. I’ve tried setting breakpoints in Node-RED, but they are not being hit.
What I’ve tried:
- Method 1: Tried debugging through Node-RED, but breakpoints in the
ui_base.jsfile located at/home/nandhini/CTCDSERV/nodered/node-red/node_modules/@flowfuse/node-red-dashboard/nodes/config/ui_base.jsaren’t working. - Method 2: Used the CLI with
node --inspect ui_base.jsto try and debug the same file.
Any suggestions on how I can properly debug the ui_base.js file in Node-RED? Specifically, how can I ensure that breakpoints are hit and function calls are tracked?
