Andres
1
Hello everyone, i have this error from nr and i can't get it to work, what does it means and how can i solve it?
Flows stopped due to missing node types.
i've tryed this but when i reintall nr it keeps showing me everything. What could it be?
Hi @Andres
it usually means you have installed a module such as node-red-contrib-ui that clashes with node-red-dashboard.
Have you installed any other dashboard-related modules recently? Check the node-red log on startup for any errors related to conflicting modules.
The fix will be to uninstall that module causing the conflict.
Andres
3
i understand, but i didn't install anything, just messed with the users of my pc. i'll check for any of those!
In which case, you might not have node-red-dashboard installed at all. That would be something to check.
What level of node.js are you using ?
Andres
6
@knolleary i have it, although i didn't use it on my implementation, at least i used to.
@dceejay i have v6.17.1, i'm ussing an older version of nr v0.20.6
Latest dashboard requires node.js v8 or more recent LTS.... As both 6 and 8 are no longer receiving security fixes I would recommend 10 or 12.
