I've been struggling with this for over a week now, but can't get it running. I'll try to be as complete as possible.
First of all: I have DeCONZ working in Home Assistant now, with a ConBee II USB dongle. This took a mere four days... This means that both the DeCONZ addon and the Phoscon/DeCONZ integration are up and running. I have one Aqara vibration sensor, which works in Home Assistant.
Settings
DeCONZ:
device: >-
/dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2220748-if00
40850/tcp deCONZ API backend
5900/tcp deCONZ via VNC
8081/tcp deCONZ WebSocket
I then added the node-red-contrib-deconz nodes in Node Red. It proved to be impossible to get an API key using the Magick get settings button, but I found the key in the log and added it.
After some fiddling, where I kept getting "connection refused" errors, I'm now at a point where I'm getting:
My settings for the config node are:
Refresh devices doesn't work.
Tail end of the DeCONS addon log (after trying refresh devices):
13:25:02:949 don't close database yet, keep open for 900 seconds
13:25:02:955 Remove websocket 192.168.178.38:40726 after error Unknown error
13:25:02:956 New websocket 172.30.32.1:53924 (state: 3)
13:25:19:763 don't close database yet, keep open for 900 seconds
13:25:19:771 New websocket 192.168.178.38:40752 (state: 3)
13:25:53:933 don't close database yet, keep open for 900 seconds
13:25:53:941 Remove websocket 192.168.178.38:40752 after error Unknown error
13:25:53:943 New websocket 192.168.178.38:40764 (state: 3)
13:25:53:965 Current channel 15
13:25:53:973 Device TTL 3752 s flags: 0x7
13:26:16:297 don't close database yet, keep open for 900 seconds
13:26:16:304 Remove websocket 192.168.178.38:40764 after error Unknown error
13:26:16:960 New websocket 192.168.178.38:40802 (state: 3)
13:26:46:239 don't close database yet, keep open for 900 seconds
13:26:46:248 Remove websocket 192.168.178.38:40802 after error Unknown error
13:26:46:249 New websocket 192.168.178.38:40810 (state: 3)
13:26:46:263 Current channel 15
13:26:46:271 Device TTL 3700 s flags: 0x7
Tail end of the NR log (after trying refresh devices):
7 Sep 13:25:02 - [warn] [deconz-server:ConBee II] WebSocket connection timeout, reconnecting
7 Sep 13:25:19 - [info] [deconz-server:ConBee II] WebSocket opened
7 Sep 13:25:32 - [warn] [deconz-server:ConBee II] WebSocket connection timeout, reconnecting
7 Sep 13:25:53 - [info] [deconz-server:ConBee II] WebSocket opened
7 Sep 13:26:06 - [warn] [deconz-server:ConBee II] WebSocket connection timeout, reconnecting
7 Sep 13:26:15 - [info] [deconz-server:ConBee II] discoverDevices: Using cached devices
[07/Sep/2020:13:26:15 +0200] 200 192.168.178.164, 172.30.32.1(172.30.32.2) GET /deconz/itemlist?controllerID=7440a617.3347e8&forceRefresh=false HTTP/1.1 (Mozilla/5.0 (X11; Linux x86_64; rv:80.0) Gecko/20100101 Firefox/80.0)
[07/Sep/2020:13:26:16 +0200] 200 192.168.178.164, 172.30.32.1(172.30.32.2) GET /deconz/itemlist?controllerID=7440a617.3347e8&forceRefresh=true HTTP/1.1 (Mozilla/5.0 (X11; Linux x86_64; rv:80.0) Gecko/20100101 Firefox/80.0)
7 Sep 13:26:16 - [info] [deconz-server:ConBee II] WebSocket opened
7 Sep 13:26:29 - [warn] [deconz-server:ConBee II] WebSocket connection timeout, reconnecting
7 Sep 13:26:46 - [info] [deconz-server:ConBee II] WebSocket opened
7 Sep 13:27:09 - [warn] [deconz-server:ConBee II] WebSocket connection timeout, reconnecting
7 Sep 13:27:28 - [info] [deconz-server:ConBee II] WebSocket opened
7 Sep 13:27:41 - [warn] [deconz-server:ConBee II] WebSocket connection timeout, reconnecting
7 Sep 13:27:53 - [info] [deconz-server:ConBee II] WebSocket opened
7 Sep 13:28:06 - [warn] [deconz-server:ConBee II] WebSocket connection timeout, reconnecting
7 Sep 13:28:32 - [info] [deconz-server:ConBee II] WebSocket opened
Can anyone help me out here?
