After successfully installing Red-Node on my MacBook Pro it will not install any additional pallets like the Victron Pallets or eWeLink pallets returning this:
Hi @logic28
The error message shown includes instructions for what to do.
You need to run the command it says to fix permissions on files under /Users/mac3/.npm
Unfortunately running: sudo chown -R 501:20 "/Users/mac3/.npm" in the terminal does not seem to have any effect.
You can manually delete the folder /Users/mac3/.npm/_cacache (please double check I've not typo'd the path...) and that should fix things as well.
Or npm cache clean --force
/Users/mac3/.npm/_cacache does not exist when I search for it ![]()
You may have to enable hidden files to see .npm. I am not sure about that on a mac though. Can you see the .npm folder? If so then what is in it?
Press Command+Shift+Dot in the Finder.
Nope, it's not appearing under any search
I shall try the command
After tat it returned: [Process completed]
In a command window can you go into the /Users/mac3 and run
npm list
and post the result here. Please copy/paste rather than screenshot. If there is lots then just the first few lines will do.
Also what does
ls -al
show?
