Dependencies ERR_DLOPEN_FAILED
Hello! I'm trying to use this RPIPLC node in Node-RED. It has a dependency with a C++ library
                "@industrialshields/rpiplc": "^2.0.0"
I'm running Node-RED on balena.io and i'm deploying the C++ library on the Node-RED container. Then I install the RPIPLC node via Node-RED UI and when I start using it I get the error ERR_DLOPEN_FAILED only on the rpiplc-config node as it has this require
Anyone has any idea?
Can you share how you are adding the C++ library to the NR container?
Hello @hardillb yes! i was pushing this to a github repo. Find it here!
Find it here https://github.com/mpous/industrialshields-ming/blob/dd57043049e3e0f94dc23261ccdfb3cca3598b8f/node-red/Dockerfile.template#L15
First quick thought, do you need to move the ldconfig to the runtime container after the copy from the build container?
I was thinking about this re-reading the Makefile... let me try @hardillb
That was it @hardillb thanks for your time! I needed 2 more eyes on this :slight_smile:
