I have tried to install widgetlord node so I can use a Pi-Spi 4-20ma current loop sensor to get data from a sensor, I followed instruction but getting this error..
Widgetlord instruction are at: Getting Started with PI-SPI Libraries – Widgetlords Electronics
Very new to node-red/raspberry pi, please help!
pi@raspberrypi:~ $ npm install node-red-contrib-widgetlords
ref-napi@1.4.1 install /home/pi/node_modules/ref-napi
node-gyp rebuild
Traceback (most recent call last):
File "/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py", line 16, in
sys.exit(gyp.script_main())
File "/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/pylib/gyp/init.py", line 545, in script_main
return main(sys.argv[1:])
File "/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/pylib/gyp/init.py", line 538, in main
return gyp_main(args)
File "/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/pylib/gyp/init.py", line 514, in gyp_main
options.duplicate_basename_check)
File "/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/pylib/gyp/init.py", line 91, in Load
generator = import(generator_name, globals(), locals(), generator_name)
MemoryError
gyp ERR! configure error
gyp ERR! stack Error: gyp failed with exit code: 1
gyp ERR! stack at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:345:16)
gyp ERR! stack at ChildProcess.emit (events.js:198:13)
gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
gyp ERR! System Linux 4.14.98-v7+
gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
gyp ERR! cwd /home/pi/node_modules/ref-napi
gyp ERR! node -v v10.16.0
gyp ERR! node-gyp -v v3.8.0
gyp ERR! not ok
npm WARN enoent ENOENT: no such file or directory, open '/home/pi/package.json'
npm WARN pi No description
npm WARN pi No repository field.
npm WARN pi No README data
npm WARN pi No license field.
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! ref-napi@1.4.1 install: node-gyp rebuild
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the ref-napi@1.4.1 install script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! /home/pi/.npm/_logs/2019-06-04T11_36_52_643Z-debug.log
