Deploy button doesn't click
Yes, tried that - and it does. So the problem is re-producable.
I've done a diff on the two .json files. I don't understand what has caused this, but here are the changes below.
Starting with the file that worked, the following changes were made that stopped it working:
Node removed:
		"id": "4fedbfaf.6bb98",
		"type": "tab",
		"label": "Flow 1",
		"disabled": false,
		"info": ""
Node removed:
  "id": "3d86e78e.17ff28",
  "type": "tab",
  "label": "Influx & Grafana",
  "disabled": false,
  "info": ""
Node removed:
		"id": "b0b4d384.fd376",
		"type": "debug",
		"z": "3d86e78e.17ff28",
		"active": true,
		"tosidebar": true,
		"console": false,
		"tostatus": false,
		"complete": "true",
		"targetType": "full",
		"x": 310,
		"y": 160,
Within this function node, the first wire was removed leaving only one wire:
		"id": "dd66451b.0f8f88",
		"type": "function",
		"func": "Sumplevel = msg.payload\nSump = msg.topic\n\nmsg.payload = {\n    level: Sumplevel,\n    sump: Sump\n    \n}\nreturn msg;",
		"outputs": 1,
		"noerr": 0,
		"x": 170,
		"y": 200,
				"b0b4d384.fd376",  **<----- REMOVED**
				"fd1c2137.60bb6"
Within this node, the value of x was changed from 570 shown below to 410:
		"id": "fd1c2137.60bb6",
		"type": "influxdb out",
		"influxdb": "9d9ad3f4.49ce7",
		"measurement": "sump_levels",
		"precision": "",
		"retentionPolicy": "",
		"x": 570,
		"y": 200,
Finally, the following was added at the end of the .json file:
		"id": "33dcee83.60bd72",
		"type": "comment",
		"name": "Sump Levels",
		"info": "",
		"x": 90,
		"y": 160,
I suspect this doesn't provide enough context to work out what caused the problem. Happy to send the whole .json file to a trusted person in private if required. @knolleary @TotallyInformation
For future reference if you post the code/flow segments using the technique detailed here then it will show them faithfully.
Thanks @Colin, I've updated my previous post!
No need, I found the problem ...
Should I mark that as the solution? :anguished:
Please do send me the 'broken' flow as a direct message here. Will look at it in the morning
Would that be considered as a cat scan?
