Hi. I have this question.
My "utility page" is formed in this way.
Is possible to have the Copyright block detached from other block like in this image?
I've tryed to work on spacer, but the result is not ok.
providing your flow would help[
As it happens
- there is a hidden div on the page called nr-dashboard-footer which you can just add what you want to and style if needed... eg
[{"id":"a2a66986.349358","type":"ui_template","z":"9138b11f.f64d5","group":"d16ec6fc.4da508","name":"","order":2,"width":0,"height":0,"format":"<script>\n$(\"#nr-dashboard-footer\").html(\"Copyright 2021 - Dave C-J\");\n</script>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"global","x":280,"y":380,"wires":[[]]},{"id":"d16ec6fc.4da508","type":"ui_group","name":"Group 2","tab":"20934cee.3e6c14","order":2,"disp":true,"width":6,"collapse":false},{"id":"20934cee.3e6c14","type":"ui_tab","name":"Tab 1","icon":"dashboard","order":1,"disabled":false,"hidden":false}]
Here is my flow.
Thank you
[{"id":"e113e00b.b59d4","type":"tab","label":"Utility","disabled":false,"info":""},{"id":"f1b954c.9241aa8","type":"comment","z":"e113e00b.b59d4","name":"Utility Server","info":"","x":110,"y":40,"wires":[]},{"id":"39a50607.77c42a","type":"ui_button","z":"e113e00b.b59d4","name":"","group":"4d6ce0e6.8b237","order":1,"width":6,"height":1,"passthru":false,"label":"Copyright","tooltip":"","color":"","bgcolor":"#A6A6A6","icon":"","payload":"Copyright © 2020 by Mariulin","payloadType":"str","topic":"","x":100,"y":820,"wires":[["73f360b6.2b7db"]]},{"id":"73f360b6.2b7db","type":"ui_toast","z":"e113e00b.b59d4","position":"dialog","displayTime":"3","highlight":"","sendall":false,"outputs":1,"ok":"OK","cancel":"","raw":false,"topic":"","name":"Messaggio a video","x":720,"y":820,"wires":[[]]},{"id":"768c6da.46e3394","type":"ui_button","z":"e113e00b.b59d4","name":"Riavvia Raspberry","group":"f3e67e3.7708b","order":2,"width":6,"height":1,"passthru":false,"label":"Riavvia Raspberry","tooltip":"","color":"","bgcolor":"#A6A6A6","icon":"fa-refresh","payload":"sudo reboot","payloadType":"str","topic":"","x":130,"y":80,"wires":[["dc0e3c2b.6e3998","d4a22fa3.6d8d9"]]},{"id":"c2ba6eb1.39c93","type":"exec","z":"e113e00b.b59d4","command":"","addpay":true,"append":"","useSpawn":"false","timer":"0","oldrc":false,"name":"Esegui Comando","x":570,"y":140,"wires":[[],[],[]]},{"id":"7644ffd7.dc38f","type":"ui_button","z":"e113e00b.b59d4","name":"Spegni Raspberry","group":"f3e67e3.7708b","order":1,"width":6,"height":1,"passthru":false,"label":"Spegni Raspberry","tooltip":"","color":"","bgcolor":"#A6A6A6","icon":"fa-power-off","payload":"sudo shutdown","payloadType":"str","topic":"","x":130,"y":180,"wires":[["b0d477ae.faf9c8","948e2dc2.1c7128"]]},{"id":"c6611b92.9e5ef8","type":"ui_button","z":"e113e00b.b59d4","name":"Riavvia Nodered","group":"f3e67e3.7708b","order":4,"width":6,"height":1,"passthru":false,"label":"Riavvia Nodered","tooltip":"","color":"","bgcolor":"#A6A6A6","icon":"fa-refresh","payload":"sudo systemctl restart nodered","payloadType":"str","topic":"","x":130,"y":280,"wires":[["cad93eb.9ce0dc","de6ebea0.080bf8"]]},{"id":"36b73974.334a06","type":"ui_toast","z":"e113e00b.b59d4","position":"dialog","displayTime":"3","highlight":"","sendall":true,"outputs":1,"ok":"OK","cancel":"","raw":false,"topic":"","name":"Messaggio a video","x":570,"y":280,"wires":[[]]},{"id":"cad93eb.9ce0dc","type":"change","z":"e113e00b.b59d4","name":"Cambia Messaggio","rules":[{"t":"change","p":"payload","pt":"msg","from":"sudo systemctl restart nodered","fromt":"str","to":"Riavvio NodeRed in corso...","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":350,"y":280,"wires":[["36b73974.334a06"]]},{"id":"de6ebea0.080bf8","type":"delay","z":"e113e00b.b59d4","name":"Ritarda 2 secondi","pauseType":"delay","timeout":"2","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":350,"y":240,"wires":[["aca8ae29.2a84e"]]},{"id":"558dae92.4b0b8","type":"ui_toast","z":"e113e00b.b59d4","position":"dialog","displayTime":"3","highlight":"","sendall":true,"outputs":1,"ok":"OK","cancel":"","raw":false,"topic":"","name":"Messaggio a video","x":570,"y":180,"wires":[[]]},{"id":"b0d477ae.faf9c8","type":"change","z":"e113e00b.b59d4","name":"Cambia Messaggio","rules":[{"t":"change","p":"payload","pt":"msg","from":"sudo shutdown","fromt":"str","to":"Spegnimento Raspberry in corso","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":350,"y":180,"wires":[["558dae92.4b0b8"]]},{"id":"948e2dc2.1c7128","type":"delay","z":"e113e00b.b59d4","name":"Ritarda 2 secondi","pauseType":"delay","timeout":"2","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":350,"y":140,"wires":[["c2ba6eb1.39c93"]]},{"id":"aca8ae29.2a84e","type":"exec","z":"e113e00b.b59d4","command":"","addpay":true,"append":"","useSpawn":"false","timer":"0","oldrc":false,"name":"Esegui Comando","x":570,"y":240,"wires":[[],[],[]]},{"id":"39ef8047.8b5b9","type":"exec","z":"e113e00b.b59d4","command":"","addpay":true,"append":"","useSpawn":"false","timer":"0","oldrc":false,"name":"Esegui Comando","x":570,"y":40,"wires":[[],[],[]]},{"id":"eab5e589.70587","type":"ui_toast","z":"e113e00b.b59d4","position":"dialog","displayTime":"3","highlight":"","sendall":true,"outputs":1,"ok":"OK","cancel":"","raw":false,"topic":"","name":"Messaggio a video","x":570,"y":80,"wires":[[]]},{"id":"dc0e3c2b.6e3998","type":"change","z":"e113e00b.b59d4","name":"Cambia Messaggio","rules":[{"t":"change","p":"payload","pt":"msg","from":"sudo reboot","fromt":"str","to":"Riavvio Raspberry in corso...","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":350,"y":80,"wires":[["eab5e589.70587"]]},{"id":"d4a22fa3.6d8d9","type":"delay","z":"e113e00b.b59d4","name":"Ritarda 2 secondi","pauseType":"delay","timeout":"2","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":350,"y":40,"wires":[["39ef8047.8b5b9"]]},{"id":"a288bac3.e4d778","type":"ui_button","z":"e113e00b.b59d4","name":"Riavvia Motion","group":"5b1e052d.73dcfc","order":1,"width":6,"height":1,"passthru":false,"label":"Riavvia Motion (REMOTO)","tooltip":"","color":"","bgcolor":"#A6A6A6","icon":"fa-refresh","payload":"sudo /root/riavvia_motion_remoto","payloadType":"str","topic":"","x":120,"y":430,"wires":[["81686cfc.2ec69","537da919.06ad88"]]},{"id":"5e38bff6.28235","type":"ui_toast","z":"e113e00b.b59d4","position":"dialog","displayTime":"3","highlight":"","sendall":true,"outputs":1,"ok":"OK","cancel":"","raw":false,"topic":"","name":"Messaggio a video","x":570,"y":430,"wires":[[]]},{"id":"81686cfc.2ec69","type":"change","z":"e113e00b.b59d4","name":"Cambia Messaggio","rules":[{"t":"change","p":"payload","pt":"msg","from":"sudo /root/riavvia_motion_remoto","fromt":"str","to":"Riavvio Motion in corso...","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":350,"y":430,"wires":[["5e38bff6.28235"]]},{"id":"537da919.06ad88","type":"delay","z":"e113e00b.b59d4","name":"Ritarda 2 secondi","pauseType":"delay","timeout":"2","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":350,"y":390,"wires":[["8f36e4ba.b75998"]]},{"id":"8f36e4ba.b75998","type":"exec","z":"e113e00b.b59d4","command":"","addpay":true,"append":"","useSpawn":"false","timer":"0","oldrc":false,"name":"Esegui Comando","x":570,"y":390,"wires":[[],[],[]]},{"id":"d464d395.df034","type":"comment","z":"e113e00b.b59d4","name":"Utility Motion","info":"","x":110,"y":390,"wires":[]},{"id":"8d55333.80544d","type":"ui_button","z":"e113e00b.b59d4","name":"Netstat","group":"aba84c21.b3a3b","order":1,"width":6,"height":1,"passthru":false,"label":"Netstat","tooltip":"","color":"","bgcolor":"#A6A6A6","icon":"fa-sitemap","payload":"sudo /bin/netstat -aW|grep LISTEN","payloadType":"str","topic":"","x":100,"y":530,"wires":[["109e3640.2db96a"]]},{"id":"109e3640.2db96a","type":"exec","z":"e113e00b.b59d4","command":"","addpay":true,"append":"","useSpawn":"false","timer":"0","oldrc":false,"name":"Esegui Comando","x":290,"y":530,"wires":[["45f12719.132c08"],[],[]]},{"id":"4e4092cf.c0d67c","type":"comment","z":"e113e00b.b59d4","name":"Utility Varie","info":"","x":100,"y":490,"wires":[]},{"id":"28615896.0ad098","type":"ui_toast","z":"e113e00b.b59d4","position":"dialog","displayTime":"3","highlight":"","sendall":false,"outputs":1,"ok":"OK","cancel":"","raw":true,"topic":"","name":"Messaggio a video","x":720,"y":520,"wires":[[]]},{"id":"b57de0fa.bfca1","type":"ui_button","z":"e113e00b.b59d4","name":"Speedtest","group":"aba84c21.b3a3b","order":2,"width":6,"height":1,"passthru":false,"label":"Speedtest","tooltip":"","color":"","bgcolor":"#A6A6A6","icon":"fa-tachometer ","payload":"sudo /usr/bin/speedtest","payloadType":"str","topic":"","x":100,"y":660,"wires":[["89ebe274.9d87","511100a5.f3639"]]},{"id":"89ebe274.9d87","type":"exec","z":"e113e00b.b59d4","command":"","addpay":true,"append":"","useSpawn":"false","timer":"0","oldrc":false,"name":"Esegui Comando","x":290,"y":660,"wires":[["7fefce30.469bf8"],[],[]]},{"id":"47929931.28ffc8","type":"ui_toast","z":"e113e00b.b59d4","position":"dialog","displayTime":"3","highlight":"","sendall":false,"outputs":1,"ok":"OK","cancel":"Cancel","raw":true,"topic":"","name":"Messaggio a video","x":720,"y":650,"wires":[[]]},{"id":"d964c797.c2bc48","type":"ui_toast","z":"e113e00b.b59d4","position":"dialog","displayTime":"3","highlight":"","sendall":false,"outputs":1,"ok":"OK","cancel":"Cancel","raw":false,"topic":"","name":"Messaggio a video","x":720,"y":710,"wires":[[]]},{"id":"511100a5.f3639","type":"change","z":"e113e00b.b59d4","name":"Cambia Messaggio","rules":[{"t":"change","p":"payload","pt":"msg","from":"sudo /usr/bin/speedtest","fromt":"str","to":"Speed Test avviato. Attendere prego...","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":290,"y":710,"wires":[["d964c797.c2bc48"]]},{"id":"45f12719.132c08","type":"template","z":"e113e00b.b59d4","name":"Formatta testo","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"<pre>{{payload}}</pre>","output":"str","x":510,"y":520,"wires":[["28615896.0ad098"]]},{"id":"b9810e25.929a6","type":"comment","z":"e113e00b.b59d4","name":"Copyright","info":"","x":95.56083679199219,"y":784.1510009765625,"wires":[]},{"id":"7fefce30.469bf8","type":"template","z":"e113e00b.b59d4","name":"Formatta testo","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"<pre>{{payload}}</pre>","output":"str","x":510,"y":650,"wires":[["47929931.28ffc8"]]},{"id":"8c61ad81.ecee8","type":"ui_button","z":"e113e00b.b59d4","name":"Who","group":"aba84c21.b3a3b","order":1,"width":6,"height":1,"passthru":false,"label":"Who","tooltip":"","color":"","bgcolor":"#A6A6A6","icon":"fa-users","payload":"sudo /usr/bin/who","payloadType":"str","topic":"","x":90,"y":590,"wires":[["f4b63610.d564f"]]},{"id":"f4b63610.d564f","type":"exec","z":"e113e00b.b59d4","command":"","addpay":true,"append":"","useSpawn":"false","timer":"0","oldrc":false,"name":"Esegui Comando","x":290,"y":590,"wires":[["bca5d5a2.945068"],[],[]]},{"id":"a5c57fa7.8686d8","type":"ui_toast","z":"e113e00b.b59d4","position":"dialog","displayTime":"3","highlight":"","sendall":false,"outputs":1,"ok":"OK","cancel":"","raw":true,"topic":"","name":"Messaggio a video","x":720,"y":580,"wires":[[]]},{"id":"bca5d5a2.945068","type":"template","z":"e113e00b.b59d4","name":"Formatta testo","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"<pre>{{payload}}</pre>","output":"str","x":510,"y":580,"wires":[["a5c57fa7.8686d8"]]},{"id":"4d6ce0e6.8b237","type":"ui_group","z":"","name":"Copyright","tab":"e609dd70.205148","order":4,"disp":true,"width":6,"collapse":false},{"id":"f3e67e3.7708b","type":"ui_group","z":"","name":"Utility Server","tab":"e609dd70.205148","order":1,"disp":true,"width":"6","collapse":false},{"id":"5b1e052d.73dcfc","type":"ui_group","z":"","name":"Utility Motion","tab":"e609dd70.205148","order":2,"disp":true,"width":"6","collapse":false},{"id":"aba84c21.b3a3b","type":"ui_group","z":"","name":"Utility Varie","tab":"e609dd70.205148","order":3,"disp":true,"width":6,"collapse":false},{"id":"e609dd70.205148","type":"ui_tab","z":"","name":"Utility","icon":"fa-cogs","order":11,"disabled":false,"hidden":false}]
Hi, in order to make code more readable and importable it is important to surround your code with three backticks
like this
You can edit and correct your post by clicking the pencil icon.
Ok. Done. Thank you
Remembering that the dashboard is a 'responsive' design, What doyou want the copyright block to doif the page is resized? Stick to the bottom all the time? or something else?
Ye[quote="zenofmud, post:7, topic:39392"]
[/quote]
Yes. In this case yes.
But my question would be more in general... Is posssible to put the block in the page in a position non in sequence with another block? For example one block on top left and another in bottom right?
Quick one to try with ui_template
<div id="test">TEST DIV</div>
<script>
$("#nr-dashboard-footer").empty();
$("#test").detach().appendTo("#nr-dashboard-footer");
</script>
<style>
#test{
position:absolute;
background:#CAFFEE;
text-align:center;
left:50%;
bottom:0;
width:200px;
height:200px;
z-index:100;
transform:translate(-50%,0%);
border:1px solid red;
</style>
If at bottom all the time then the code I posted above is the way to do it.
Otherwise the default is for a responsive display that changes to try to accommodate different screen sizes. So while you could create one large group and then use the layout tool to place widgets within it, you can’t easily place groups .
