Can any one help with below error codes when installing DHT node for pi3.
Many thanks
Installation of module node-red-contrib-dht-sensor failed:"
10/28/2018, 9:14:55 PMmsg : string[42]
10/28/2018, 9:14:55 PMmsg : string[14122]
"↵> node-dht-sensor@0.0.34 preinstall /home/pi/.node-red/node_modules/node-dht-sensor↵> ./check-lib.sh↵↵+--------------------------------------------------------------------------------+↵| e[1;31mERROR: Library BCM2835 not found!e[0m |↵| Make sure you follow instructions from http://www.airspayce.com/mikem/bcm2835/ |↵| to install the BCM2835 library on your system first then install this addon. |↵+--------------------------------------------------------------------------------+↵↵> node-dht-sensor@0.0.34 install /home/pi/.node-red/node_modules/node-dht-sensor↵> node-gyp configure↵↵↵> node-dht-sensor@0.0.34 postinstall /home/pi/.node-red/node_modules/node-dht-sensor↵> node-gyp build↵↵make: Entering directory '/home/pi/.node-red/node_modules/node-dht-sensor/build'↵ CXX(target) Release/obj.target/node_dht_sensor/node-dht-sensor.o↵In file included from ../../nan/nan_new.h:189:0,↵ from ../../nan/nan.h:203,↵ from ...."
