Hi all,
I am currently doing an application in which it is compulsory to have a certain module disabled, as if I had touched this button from the palette:
My problem is that whilst I need to have this module installed because I call it from NodeJS, If node-red enables it, it really affects the stability of my application.
Is there a way to disable it (for instance from a configuration file, then rebooting node-red) from inside the application?
Thank you in advance
What does this mean? Are you running a separate node js application that requires this node? (or something this node installs?)
Yes, I require the c++ binaries of the module.
I'm sorry but that makes zero sense?
node-red-contrib-mqttssl is over 6 years old and all it does is import a very very old version of "mqtt"
See for your self here
Perhaps if you explain clearer what you are trying to achieve we can show you a way without adding node-red-contrib-mqttssl to your node-red installation.
