Display 2 extracts from influxdb in an UI-Chart
Hi!
I am extracting the power consumption and the power consumption within the last hour from an influxdb.
the flow looks like:
After the extract is formated i get 2 arrays of the object:
With the Chart node I can display each object separately - without any problem
I want to combine both charts to be displayed in one chart - the flow should look like:
But it shows only the power consumption, since this is the last extract.
Any idea how to do this?
Thanks Georg
you need to set the data in this format, this will give a 2 lines on same chart
[{"series":["A","B"],"data":[[{"x":1504029632890,"y":5},{"x":1504029636001,"y":4},{"x":1504029638656,"y":2}],[{"x":1504029633514,"y":6},{"x":1504029636622,"y":7},{"x":1504029639539,"y":6}]],"labels":["a","b"]}]
edit remove character form end of array
which means @JungeG will have to join the two msgs
Thanks!
This was the right hint.
Add a join node and a new function:
The flow looks like now:
Results after Join InfluxDB Extract - 2 arrays in one node.
Reformate the payload using following function:
the new chart looks as expected:
now you can switch between the data:
Hope this is a clear explanation.
Thanks again
Georg
Are you sure you can't get both sets of data in one query? What are the queries?
Hi Collin!
The query is just a select * from the measurement:
Select 1:
select * from EN01_Power where time >= now() - 14h
Select 2:
select * from EN01_PowerShift where time >= now() - 14h
How can I combine them to have only one query?
Thanks for guidance.
Georg
What are the fields and tags in those two measurements?
I was going to suggest rearranging your measurments, and this may still be worthwile, but looking at the docs for the select statement I see you can do
select * from EN01_Power, EN01_PowerShift where time >= now() - 14h
Thanks Colin,
but if I re-arrange the select statement - I get one array with just the EN01_Power data.
Do I need an into clause?
The only fields are time and value in both measurements.
show field keys:
and the select on EN01_Power:
and the select on EN01_Power, EN01_PowerShift:
Only the EN01_Power values are selected.
Georg
You have missed the _ from the measurement name
You are right - my fault:
but the extract in node-red ist still only the EN01_Power values.
Georg
How are you doing the extract in node-red?
I have just tried with the Influxdb In node with a query
select * from m1,m2 limit 10
and I get 20 rows with the combined data fields. If the timestamps were the same for some of the samples it might combine them I don't know.
Thanks Colin,
I have now extracted the data as Raw Data:
and formatted the data as follows:
var series = [msg.payload.results[0].series[0].name, msg.payload.results[0].series[1].name];
var labels = [msg.payload.results[0].series[0].name, msg.payload.results[0].series[1].name];
var data0 = "[[";
var thetime0;
for (var i=0; i < msg.payload.results[0].series[0].values.length; i++) {
thetime0 = (msg.payload.results[0].series[0].values[i][0]); // Some manipulation of the time may be required
thetime0 = Date.parse(thetime0);
data0 += '{ "x":' + thetime0 + ', "y":' + msg.payload.results[0].series[0].values[i][1] + '}';
if (i < (msg.payload.results[0].series[0].values.length - 1)) {
data0 += ","
} else {
data0 += "]]"
var data1 = "[[";
var thetime1;
for (var j=0; j < msg.payload.results[0].series[1].values.length; j++) {
thetime1 = (msg.payload.results[0].series[1].values[j][0]); // Some manipulation of the time may be required
thetime1 = Date.parse(thetime1);
data1 += '{ "x":' + thetime1 + ', "y":' + msg.payload.results[0].series[1].values[j][1] + '}';
if (j < (msg.payload.results[0].series[1].values.length - 1)) {
data1 += ","
} else {
data1 += "]]"
var data = [data0, data1];
var jsondata = [JSON.parse(data0), JSON.parse(data1)];
//var jsondata = JSON.parse(data1);
msg.payload = [{"series": series, "data": jsondata, "labels": labels}];
msg.playload = data;
Get the data in same format as with the earlier solution, but in less steps:
the chart looks like:
the lines are not drawn - if I use only one serie, var jsondata = JSON.parse(data0); it is displayed correctly:
Any idea?
Thanks Georg
That "data" array is not correct. From the docs it should be
"series": ["A", "B", "C"],
"data": [
    [{ "x": 1504029632890, "y": 5 },
     { "x": 1504029636001, "y": 4 },
     { "x": 1504029638656, "y": 2 }
    [{ "x": 1504029633514, "y": 6 },
     { "x": 1504029636622, "y": 7 },
     { "x": 1504029639539, "y": 6 }
    [{ "x": 1504029634400, "y": 7 },
     { "x": 1504029637959, "y": 7 },
     { "x": 1504029640317, "y": 7 }
"labels": [""]
So "data" should be an array, with one element per series and each of those elements should be a simple array of points. You have an array of two elements, which is ok, but you have each of those as an array of 1 element, containing the array of points.
Hi Colin,
thanks for the hint:
the problem lies with the double [] during the conversion, if I use single than it is okay.
So I repost the conversion:
var data0 = "[";
var thetime0;
data0 += ","
} else {
data0 += "]"
var data1 = "[";
var thetime1;
data1 += ","
} else {
data1 += "]"
The data section now looks:
which is one array less.
Thanks for you help
Georg
