Need help with OMRON fins node. I want to display value from FINS read multiple node in a dashboard widget/gauge.
Below are the tag addresses.
W100.00,W100.01,W100.02,W100.03,W100.04,W100.05,W100.06,W100.07,W101.00,W101.01,W101.02,W101.03,W101.04,W101.05,W101.06,W101.07,W102.00,W102.01,W102.02
How should I give input? like this - msg.payload.W100.01 ? I tried but it's not working.
[{"id":"3fba64fb.1255ac","type":"FINS Read Multiple","z":"b1f5580f.0b59c8","name":"","connection":"18d34fc5.6dc1f","addressType":"str","address":"W100.00,W100.01,W100.02,W100.03,W100.04,W100.05,W100.06,W100.07,W101.00,W101.01,W101.02,W101.03,W101.04,W101.05,W101.06,W101.07,W102.00,W102.01,W102.02","msgPropertyType":"msg","msgProperty":"payload","outputFormatType":"signedkv","outputFormat":"","x":1740,"y":140,"wires":[["e9cce256.528bc"]]},{"id":"5b750fa8.befdd","type":"inject","z":"b1f5580f.0b59c8","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":1470,"y":140,"wires":[["3fba64fb.1255ac"]]},{"id":"e9cce256.528bc","type":"function","z":"b1f5580f.0b59c8","name":"","func":"msg.payload=msg.payload.W100.01;\nreturn msg;","outputs":1,"noerr":2,"initialize":"","finalize":"","libs":[],"x":2000,"y":140,"wires":[["b29ccd43.d6134"]]},{"id":"b29ccd43.d6134","type":"debug","z":"b1f5580f.0b59c8","name":"","active":true,"tosidebar":false,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":2150,"y":140,"wires":[]},{"id":"18d34fc5.6dc1f","type":"FINS Connection","name":"Holding furnace","host":"192.168.1.3","port":"9600","MODE":"","MODEType":"CS","protocol":"","protocolType":"udp","ICF":"0x80","DNA":"0","DA1":"0","DA2":"0","SNA":"0","SA1":"12","SA2":"0","autoConnect":true}]
