Display tooltip as label on switch node
I want to show the tooltips/output names/conditons on the switch node as a label.
Visual example:
How can this be achieved in the GUI Editor?
Welcome to the forum @zfox
Have you spotted that hovering over the node's outputs will show the condition that the output meets?
Yes, I have spotted that tooltip. However I'd like to always display something like this tooltip, regardless of mouse position
Unfortunately that is not possible. You could achieve something like this
by using a newline in the node name field - test\n test2\n test3
I usually use a name for the switch with a question mark.
'output ?'
'color ?'
'device ?'
it gives a clear indication (to me) what the switch condition is looking for and it is limited to. I know that doesn't help you in your question, but just a tip as it makes flows much more readable. (would recommend to rename all nodes in similar fashion)
