Switch node improvement
I have a couple of flows with switch nodes containing multiple outputs. If I hover over an output it will show a tooltip which describes the output but it would be really nice to see an annotation against each output with that description, or a simplified version, so I can look at a flow and instantly see which outputs do what.
I have no idea how to do this or I might consider trying to take on such a customisation myself.
You know you can set the descriptions to whatever you wish in the edit node properties?
I didn't know that!
You can do it with a function node (which has no default tooltips) too!
I agree with @IanAber that it would be nice not to have to hover over each port to see the tooltips.
Perhaps a right click option to open an iframe with the node description and port tooltips might be possible?
