Node-red is gradually acquiring more ways to include documentation in a flow, and to read it.
You can add a tooltip to function node (only?) outputs.
Tooltips are automatic for switch nodes
Groups allow a description
Is it desirable to allow a wire to have a description, to be visible when the wire is clicked?
This proposal has been discussed before, eg https://discourse.nodered.org/t/add-labels-to-wires-in-editor/50133
I know that a wire has no entry in flows.json, it only exists in the definition of the originating node as the id of the node it links to.
However, there is some devilry afoot which allows you to click on a wire and select it.
Wires are not straight - can we create a curved line of text along the wire by CSS?
Position of the displayed text - the centre of the wire? Adjacent to the node it links to ("right justified")?
If a comment is longer than it's wire, don't overflow.
Definition:
"outputs": 2,
"x": 590,
"y": 180,
"fcce9fc403afc77b"
"dd35dd2bbd582f93"
"wire comments": [
{"id": "fcce9fc403afc77b", "comment": "Steam traction"},
{"id": "dd35dd2bbd582f93", "comment": "Electric traction"}
