Displaying html page on ui template
Hello everyone (please be nice this is my first time and I am very much a noob)
The problem I have seems like it must have an obvious answer, but I'm stumped.
I'm using a template node to write html which will change according to the msg.payload:-
<!Doctype Html>
<Html>
<Head>
<style>
.rotate{{payload}} {
  -webkit-transform:rotate({{payload}}deg);
  -moz-transform: rotate({{payload}}deg);
  -ms-transform: rotate({{payload}}deg);
  -o-transform: rotate({{payload}}deg);
</style>
</Head>
<Body>
<img src="http://hailshamhistoricalsociety.co.uk/images/Museum-entrance.png" width="100" height="100" class="rotate{{payload}}">
</Body>
</Html>
This is then sent to a ui template with default text (<div ng-bind-html="msg.payload"></div>)
The problem is that although the image shows up in the dashboard it doesn't rotate, but if I paste the output (captured by a default node) directly into the ui template it works fine!
Could anyone tell me what is happening?
Any help very gratefully recieved.
Kind regards
Paul
I would think the head and body tags are not required, As you are not rendering the full page. Dashboad has already used those tags. try its like this
[{"id":"4e43e998.a15018","type":"ui_template","z":"c74669a0.6a34f8","group":"2d4fe667.28f8ba","name":"","order":6,"width":0,"height":0,"format":"","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"local","x":430,"y":2140,"wires":[[]]},{"id":"c9137879.569d7","type":"template","z":"c74669a0.6a34f8","name":"","field":"template","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"<style>  \n.rotate{{payload}} {  \n  -webkit-transform:rotate({{payload}}deg);  \n  -moz-transform: rotate({{payload}}deg);  \n  -ms-transform: rotate({{payload}}deg);  \n  -o-transform: rotate({{payload}}deg);  \n  transform: rotate({{payload}}deg);  \n}  \n</style>  \n<img src=\"http://hailshamhistoricalsociety.co.uk/images/Museum-entrance.png\" width=\"100\" height=\"100\" class=\"rotate{{payload}}\">","output":"str","x":250,"y":2140,"wires":[["4e43e998.a15018"]]},{"id":"65c626ad.2f448","type":"inject","z":"c74669a0.6a34f8","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"90","payloadType":"num","x":100,"y":2140,"wires":[["c9137879.569d7"]]},{"id":"2d4fe667.28f8ba","type":"ui_group","name":"demo","tab":"1caa8458.b17814","order":1,"disp":true,"width":"6","collapse":false},{"id":"1caa8458.b17814","type":"ui_tab","name":"Demo","icon":"dashboard","disabled":false,"hidden":false}]
Nor the html tags
Hi there thankyou very much for all the replies however it still doesn't work.
As an aside I don't really understand the reply from E1cid, could you tell me what format the code is that you've written in / where its supposed to go?:wink:
Does anyone know if there is a specific reason why the html works fine if pasted into the ui template, but if sent from a normal template the image shows, but doesn't rotate?
What I would like to do is in some way just display an image on the dashboard that rotates by the number of degrees sent in the msg.payload. Should i possibly try a different method?
Again many thanks for your help
Paul
I have not added any code, I just removed your html, head and body tags from your html. Then in the template node I set it to msg.template.
From the image below you can see it rotated 90 degrees.
That website is local to me, small world.
Post your example flow with the issue.
[edit] The reason it is not working direct in ui-template is you have used
{{payload}}
while in ui-template it is
{{msg.payload}}
eg.
[{"id":"cd47d5fb.f6e3e8","type":"inject","z":"c74669a0.6a34f8","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"90","payloadType":"num","x":170,"y":2860,"wires":[["9c02d482.9d5358"]]},{"id":"9c02d482.9d5358","type":"ui_template","z":"c74669a0.6a34f8","group":"8b5cde76.edd58","name":"","order":5,"width":0,"height":0,"format":"<style>  \n.rotate{{msg.payload}} {  \n  -webkit-transform:rotate({{msg.payload}}deg);  \n  -moz-transform: rotate({{msg.payload}}deg);  \n  -ms-transform: rotate({{msg.payload}}deg);  \n  -o-transform: rotate({{msg.payload}}deg);  \n  transform: rotate({{msg.payload}}deg);  \n}  \n</style>  \n<img src=\"http://hailshamhistoricalsociety.co.uk/images/Museum-entrance.png\" width=\"100\" height=\"100\" class=\"rotate{{msg.payload}}\">","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"local","x":320,"y":2860,"wires":[[]]},{"id":"8b5cde76.edd58","type":"ui_group","name":"","tab":"8f03e639.85956","order":1,"disp":true,"width":"12","collapse":false},{"id":"8f03e639.85956","type":"ui_tab","name":"Home","icon":"dashboard","disabled":false,"hidden":false}]
Thank you so much E1cid (I live in Hailsham btw) its worksssss!!
The key thing was changing the template payload to msg.template, but I have no idea why, could you possibly explain, I have trawled the internet. but can't find an explanation.
I actually used the below instead of the tab to achieve the same thing but in less lines:-
    <script>
        document.querySelector("#img").style.transform = "rotate({{payload}}deg)";
    </script>
Many thanks again. BTW if you would consider giving lessons, I would be very interested.
Kind regards
Paul
form the ui-template help
Using msg.template :
You can also define the template content via msg.template , so you can use external files for example.
Template will be reloaded on input if it has changed.
Code written in the Template field will be ignored when msg.template is present.
[edit] I'm from the Bourne, message me if you need further assistance, I'm not a IT expert but over the years have developed some knowledge.
