Hi
Is it possible to create a double ended slider like this? Or a circular one with both ends adjustable?
Thanks!
Many examples can be found from web. Mostly done using two range type input elements and a bit of JavaScript to have unified control over those.
For example: https://codepen.io/joosts/pen/rNLdxvK
So yes, it is possible to create such thing using ui_template node.
Thank you for that...... I will probably stick with two sliders currently - but maybe one day someone will do a max/min type node....
