Download Multipart File to Node Red with HTTP Get Request
I am trying to download a file from a server to Node Red then save as a file. The file is hosted on a server that responds to a GET request. Currently, the flow downloads part of the file using an HTTP request node and a file node, but not the whole thing. I can download the whole file with Postman, but using Node Red, i only get about 14kb of the 2.5MB file.
[{"id":"9d9d51eb.66525","type":"tab","label":"Download Pertus","disabled":false,"info":""},{"id":"741f50bf.487e7","type":"inject","z":"9d9d51eb.66525","name":"","topic":"DownloadPertu","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":310,"y":100,"wires":[["6aa4d239.1599ac"]]},{"id":"6aa4d239.1599ac","type":"change","z":"9d9d51eb.66525","name":"","rules":[{"t":"set","p":"timestamp","pt":"msg","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":290,"y":140,"wires":[["26ecf671.880a6a"]]},{"id":"26ecf671.880a6a","type":"template","z":"9d9d51eb.66525","name":"Build msg.url","field":"url","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"http://172.1.1.1:80/peccgi/system/driver/HDMDRV?request=listFiles&group=PERTU","output":"str","x":270,"y":180,"wires":[["d2d5213d.67719"]]},{"id":"d2d5213d.67719","type":"http request","z":"9d9d51eb.66525","name":"","method":"GET","ret":"txt","paytoqs":false,"url":"","tls":"","persist":false,"proxy":"","authType":"","x":270,"y":220,"wires":[["7c00d646.1b6018"]]},{"id":"9f5148d7.327a18","type":"debug","z":"9d9d51eb.66525","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":250,"y":580,"wires":[]},{"id":"7c00d646.1b6018","type":"xml","z":"9d9d51eb.66525","name":"","property":"payload","attr":"","chr":"","x":250,"y":260,"wires":[["47b40763.a27678"]]},{"id":"47b40763.a27678","type":"change","z":"9d9d51eb.66525","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.hpc.StorageGroup.File","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":280,"y":300,"wires":[["f291e33.4d1972"]]},{"id":"363f2a70.80ad76","type":"http request","z":"9d9d51eb.66525","name":"","method":"GET","ret":"bin","paytoqs":false,"url":"","tls":"","persist":true,"proxy":"","authType":"","x":270,"y":460,"wires":[["3b0ba9ea.269ee6"]]},{"id":"3b0ba9ea.269ee6","type":"file","z":"9d9d51eb.66525","name":"","filename":"","appendNewline":false,"createDir":true,"overwriteFile":"true","encoding":"binary","x":250,"y":520,"wires":[["9f5148d7.327a18"]]},{"id":"f291e33.4d1972","type":"change","z":"9d9d51eb.66525","name":"","rules":[{"t":"set","p":"filename","pt":"msg","to":"payload[0].$.time","tot":"msg"},{"t":"set","p":"url","pt":"msg","to":"payload[0].$.url","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":280,"y":340,"wires":[["2a337b28.3eb6d4"]]},{"id":"2a337b28.3eb6d4","type":"function","z":"9d9d51eb.66525","name":"","func":"msg.filename = '/home/dev/unsecured/' + msg.filename + '.per';\nreturn msg;","outputs":1,"noerr":0,"x":250,"y":380,"wires":[["363f2a70.80ad76"]]}]
Hi and welcome to the forum. Firstly, you flow will not be usable as it's not formatted correctly..
In order to make code more readable and importable it is important to post it between two sets of three backticks - ``` - see this post for more details - How to share code or flow json
Sorry about that, should be good now.
I'm unable to load that address here, but can you share the Postman request with the full response headers? I'm quite curious in how to solve this, as it might be useful in different situations too.
Yeah, you wouldn't be able to access the address. It is a local IOT device. Sorry, I know that makes troubleshooting difficult.
I think this is the response headers and request that you are looking for.
