I have tried Paul-Reed's Node-Red on a Pi backup flow, which works well. However, I would like to use it on several Pis so I want to amend the save filename to include an identifier. At the moment I am using a Change Node after the DSM Node to edit the filename but I would prefer to add this data from the Inject Node.
Is there any way of sending the DSM Node information that it can use as part of its output?
[edited by @cymplecy to add context to the question node-RED Backup Flow [/edit]
