Dynamic gauge dashboard 2 property
hello,
I'm stuck on a small code problem that I can't transform into dachboard 2.
below code which works for "gauge" dashboard 1 and which does not work in dachboard 2.
Is there a manual for dynamic properties per dashboard 2 node?
could you help me?
Thank you in advance and have a nice day.
Dashboard v1
var data = 20;
var max = 20 + (20/4);
msg.ui_control = { "min": 0, "max": max };
Dashboard v2
var data = 20;
msg = {
    "ui_control": {
        "min": 0,
        "max": max
    "ui_update": {
        "label": "New Label"
At the moment no. You can see here: Gauge ui-gauge | Node-RED Dashboard 2.0 - The table will have ticks against in the dynamic column when supported.
NOTE: this is something we will support. Work is ongoing and you can see the status here: Modify/Update UI-widget parameters from external · Issue #833 · FlowFuse/node-red-dashboard · GitHub
