Editor stuck at "Adding Flows to workspace"
After upgrade to 1.2, the editor stops at "Adding Flows to workspace". It appears to be the same issue experienced here:
I'm afraid I cannot follow the debugging steps used before. Is there an easier way to find and remove the offending node? If that is the likely problem?
Hi @taisau
How do you run Node-RED?
If you can set the NODE_ENV environment variable to development before running Node-RED, then you'll get the non-minified version of the editor code - so the stack traces will be easier to follow.
Thanks, @knolleary.
Running on a raspberry pi, installed with the script.
It would appear that it is brads-i2c-nodes causing it.
I'll try reinstalling or rebuilding the node.
Starting as a systemd service.
15 Oct 09:40:48 - [info]
Welcome to Node-RED
15 Oct 09:40:48 - [info] Node-RED version: v1.2.0
15 Oct 09:40:48 - [info] Node.js  version: v14.13.1
15 Oct 09:40:48 - [info] Linux 4.19.97-v7l+ arm LE
15 Oct 09:40:48 - [info] Loading palette nodes
15 Oct 09:40:51 - [info] Dashboard version 2.23.4 started at /ui
15 Oct 09:40:51 - [warn] ------------------------------------------------------
15 Oct 09:40:51 - [warn] [node-red-contrib-brads-i2c-nodes/bmp180] Error: The module '/home/pi/.node-red/node_modules/i2c-bus/build/Release/i2c.node'
was compiled against a different Node.js version using
NODE_MODULE_VERSION 64. This version of Node.js requires
NODE_MODULE_VERSION 83. Please try re-compiling or re-installing
the module (for instance, using `npm rebuild` or `npm install`).
I am getting the same problem with a variation in that if I uninstall and reinstall Node-RED.
It works for about six hours and then starts exhibiting the problem.
28 Oct 17:00:04 - [info]
Welcome to Node-RED
28 Oct 17:00:04 - [info] Node-RED version: v1.2.2
28 Oct 17:00:04 - [info] Node.js  version: v14.15.0
28 Oct 17:00:04 - [info] Linux 5.4.72-v7l+ arm LE
28 Oct 17:00:04 - [info] Loading palette nodes
28 Oct 17:00:06 - [info] Dashboard version 2.23.4 started at /ui
28 Oct 17:00:07 - [info] Settings file  : /home/pi/.node-red/settings.js
28 Oct 17:00:07 - [info] Context store  : 'default' [module=memory]
28 Oct 17:00:07 - [info] User directory : /home/pi/.node-red
28 Oct 17:00:07 - [warn] Projects disabled : editorTheme.projects.enabled=false
28 Oct 17:00:07 - [info] Flows file     : /home/pi/.node-red/flows_raspberrypi.json
28 Oct 17:00:07 - [info] Creating new flow file
your credentials.
28 Oct 17:00:07 - [info] Server now running at http://127.0.0.1:1880/
28 Oct 17:00:07 - [info] Starting flows
28 Oct 17:00:07 - [info] Started flows
After installing Node-RED I use the pallet manger to also install:
node-red-dashboard
node-red-contrib-ds18b20-sensor
node-red-contrib-unit-converter
node-red-contrib-alexa-remote2
@victronenergy/node-red-contrib-victron
I had done an export with all flows as a backup.
Which I used to recover from after reinstalling NodeRED. There is some hidden error in that process.
It seems to be stable after:
  1. Importing all flows.
  2. Export the individual flows separately.
  3. Delete all flows and configurations
  4. reimport each flow individually
I never really pinpointed my problem, just solved it by std procedure of removing and changing random things. I also had the Victron nodes installed, and I recall a msg stating something like they did not have valid node id's. My impression was that the 1.22 update identified and isolated those invalid nodes, where the 1.20 did not.
I spoke too soon the problem has reappeared. The last thing I remember doing last night was adding the Victron library and coding up some web GUI.
I have an older NodeRED installation that is running the Victron library, will have the required functionality output to MQTT and then under 1.2.2 consume for the web GUI.
Definitely somewhere in the Victron nodes!!! I did the following commands and it loaded the flows with a warning about the missing nodes.
  • sudo systemctl stop nodered
  • cd ~/.node-red
  • npm remove @victronenergy/node-red-contrib-victron
  • sudo systemctl start nodered
Here's flow that I believe causes the error:
[{"id":"3641ab29.985114","type":"tab","label":"Inverter GUI","disabled":false,"info":""},{"id":"f523c82e.de4cf8","type":"ui_chart","z":"3641ab29.985114","name":"","group":"61d8c7f4.833fe8","order":0,"width":0,"height":0,"label":"Voltage","chartType":"line","legend":"false","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":false,"ymin":"","ymax":"","removeOlder":"3","removeOlderPoints":"","removeOlderUnit":"86400","cutout":0,"useOneColor":false,"useUTC":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"useOldStyle":false,"outputs":1,"x":820,"y":300,"wires":[[]]},{"id":"4c2c817e.3de9b","type":"ui_chart","z":"3641ab29.985114","name":"","group":"61d8c7f4.833fe8","order":0,"width":0,"height":0,"label":"State of Charge","chartType":"line","legend":"false","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":false,"ymin":"","ymax":"","removeOlder":"3","removeOlderPoints":"","removeOlderUnit":"86400","cutout":0,"useOneColor":false,"useUTC":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"useOldStyle":false,"outputs":1,"x":840,"y":360,"wires":[[]]},{"id":"949328e8.3caed8","type":"ui_chart","z":"3641ab29.985114","name":"","group":"61d8c7f4.833fe8","order":0,"width":0,"height":0,"label":"Battery Temperature","chartType":"line","legend":"false","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":false,"ymin":"","ymax":"","removeOlder":"3","removeOlderPoints":"","removeOlderUnit":"86400","cutout":0,"useOneColor":false,"useUTC":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"useOldStyle":false,"outputs":1,"x":860,"y":420,"wires":[[]]},{"id":"83c45074.65f9a","type":"ui_chart","z":"3641ab29.985114","name":"","group":"61d8c7f4.833fe8","order":0,"width":0,"height":0,"label":"Wattage","chartType":"line","legend":"false","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":false,"ymin":"","ymax":"","removeOlder":"3","removeOlderPoints":"","removeOlderUnit":"86400","cutout":0,"useOneColor":false,"useUTC":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"useOldStyle":false,"outputs":1,"x":820,"y":480,"wires":[[]]},{"id":"cc4a38e3.d2b3e8","type":"rbe","z":"3641ab29.985114","name":"","func":"rbe","gap":"","start":"","inout":"out","property":"payload","x":480,"y":320,"wires":[["f523c82e.de4cf8"]]},{"id":"395f055e.546bda","type":"rbe","z":"3641ab29.985114","name":"","func":"rbe","gap":"","start":"","inout":"out","property":"payload","x":480,"y":380,"wires":[["4c2c817e.3de9b"]]},{"id":"dee506d2.14cde8","type":"rbe","z":"3641ab29.985114","name":"","func":"rbe","gap":"","start":"","inout":"out","property":"payload","x":480,"y":440,"wires":[["949328e8.3caed8"]]},{"id":"769bb4c8.25cbbc","type":"rbe","z":"3641ab29.985114","name":"","func":"rbe","gap":"","start":"","inout":"out","property":"payload","x":480,"y":500,"wires":[["83c45074.65f9a"]]},{"id":"e5b8081f.e3a3e8","type":"mqtt in","z":"3641ab29.985114","name":"MQTT Inverter/#","topic":"Inverter/#","qos":"2","datatype":"auto","broker":"60346d2e.382554","x":140,"y":140,"wires":[["83046f3e.2f173"]]},{"id":"83046f3e.2f173","type":"function","z":"3641ab29.985114","name":"true/false on/off Conversion\\n to Boolean","func":"if (msg.topic.includes(\"/relay\"))\n{\n    cmd = msg.payload.toLowerCase();\n    if (cmd === \"on\")\n    {\n        msg.payload = true;\n        return msg;\n    }\n    if (cmd === \"true\")\n    {\n        msg.payload = true;\n        return msg;\n    }\n    if (cmd === \"false\")\n    {\n        msg.payload = false;\n        return msg;\n    }\n    if (cmd === \"off\")\n    {\n        msg.payload = false;\n        return msg;\n    }\n}\nreturn null;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":420,"y":140,"wires":[["902c9abd.029cd8"]]},{"id":"3ca5eeb4.f6cfe2","type":"switch","z":"3641ab29.985114","name":"Switch router","property":"topic","propertyType":"msg","rules":[{"t":"cont","v":"Power/relay","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":990,"y":140,"wires":[["b3f8b14f.f3b0e"]],"info":"Switch node to router MQQT messages to the appropiate relay pin\n"},{"id":"288e812f.36306e","type":"link in","z":"3641ab29.985114","name":"","links":["6a899de4.953684"],"x":1075,"y":180,"wires":[["b3f8b14f.f3b0e"]]},{"id":"b3f8b14f.f3b0e","type":"ui_switch","z":"3641ab29.985114","name":"","label":"Inverter Power Relay","tooltip":"Inverter Power control relay","group":"f8656422.5ed208","order":6,"width":0,"height":0,"passthru":false,"decouple":"true","topic":"Inverter/Power/relay","style":"","onvalue":"true","onvalueType":"bool","onicon":"","oncolor":"","offvalue":"false","offvalueType":"bool","officon":"","offcolor":"","x":1200,"y":140,"wires":[["6a899de4.953684","6ed59ef8.be6d8"]]},{"id":"6a899de4.953684","type":"link out","z":"3641ab29.985114","name":"","links":["288e812f.36306e"],"x":1295,"y":180,"wires":[]},{"id":"a4ec04fb.959dd8","type":"comment","z":"3641ab29.985114","name":"Gui Control Switch","info":"","x":150,"y":80,"wires":[]},{"id":"902c9abd.029cd8","type":"function","z":"3641ab29.985114","name":"Save inverterState\\n to global memory","func":"global.set('inverterState', msg.payload.toString());\nif (msg.payload === false)\n{\n    global.set('power0', \"0\");\n    global.set('power1', \"0\");\n}\nif (msg.payload === true)\n{\n    global.set('inverterCountdown', \"10\");\n}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":730,"y":140,"wires":[["3ca5eeb4.f6cfe2"]]},{"id":"6ed59ef8.be6d8","type":"mqtt out","z":"3641ab29.985114","name":"MQTT Inverter stuff ","topic":"","qos":"2","retain":"true","broker":"6311a09c.95026","x":1490,"y":140,"wires":[]},{"id":"4679e2dd.7e358c","type":"victron-input-battery","z":"3641ab29.985114","service":"com.victronenergy.battery.socketcan_can0","path":"/Dc/0/Voltage","serviceObj":{"service":"com.victronenergy.battery.socketcan_can0","name":"SIMP BMS","paths":[{"path":"/Dc/0/Voltage","type":"float","name":"Battery voltage (V)"},{"path":"/Dc/0/Current","type":"float","name":"Current (A)"},{"path":"/Soc","type":"float","name":"State of charge (%)"},{"path":"/Dc/0/Temperature","type":"float","name":"Battery temperature (C)"},{"path":"/Alarms/LowVoltage","type":"enum","name":"Low voltage alarm","enum":{"0":"No alarm","2":"Alarm"}},{"path":"/Alarms/HighVoltage","type":"enum","name":"High voltage alarm","enum":{"0":"No alarm","2":"Alarm"}},{"path":"/Alarms/LowTemperature","type":"enum","name":"Low battery temperature alarm","enum":{"0":"No alarm","2":"Alarm"}},{"path":"/Alarms/HighTemperature","type":"enum","name":"High battery temperature alarm","enum":{"0":"No alarm","2":"Alarm"}},{"path":"/Soh","type":"float","name":"State of health (%)"},{"path":"/Info/MaxChargeVoltage","type":"float","name":"CVL - Charge Voltage Limit (V)"},{"path":"/Info/MaxChargeCurrent","type":"float","name":"CCL - Charge Current Limit (A)"},{"path":"/Info/MaxDischargeCurrent","type":"float","name":"DCL - Discharge Current Limit (A)"},{"path":"/Alarms/CellImbalance","type":"enum","name":"Cell Imbalance alarm","enum":{"0":"No alarm","1":"Warning","2":"Alarm"}},{"path":"/Alarms/HighChargeCurrent","type":"enum","name":"High charge current alarm","enum":{"0":"No alarm","1":"Warning","2":"Alarm"}},{"path":"/Alarms/HighDischargeCurrent","type":"enum","name":"High discharge current alarm","enum":{"0":"No alarm","1":"Warning","2":"Alarm"}},{"path":"/Alarms/InternalFailure","type":"enum","name":"Internal error alarm","enum":{"0":"No alarm","1":"Warning","2":"Alarm"}},{"path":"/Alarms/HighChargeTemperature","type":"enum","name":"High charge temperature alarm","enum":{"0":"No alarm","1":"Warning","2":"Alarm"}},{"path":"/Alarms/LowChargeTemperature","type":"enum","name":"Low charge temperature alarm","enum":{"0":"No alarm","1":"Warning","2":"Alarm"}},{"path":"/Dc/0/Power","type":"float","name":"Battery power (W)"}]},"pathObj":{"path":"/Dc/0/Voltage","type":"float","name":"Battery voltage (V)"},"name":"","x":190,"y":300,"wires":[["cc4a38e3.d2b3e8"]]},{"id":"7ca3b39.8f0f44c","type":"victron-input-battery","z":"3641ab29.985114","service":"com.victronenergy.battery.socketcan_can0","path":"/Soc","serviceObj":{"service":"com.victronenergy.battery.socketcan_can0","name":"SIMP BMS","paths":[{"path":"/Dc/0/Voltage","type":"float","name":"Battery voltage (V)"},{"path":"/Dc/0/Current","type":"float","name":"Current (A)"},{"path":"/Soc","type":"float","name":"State of charge (%)"},{"path":"/Dc/0/Temperature","type":"float","name":"Battery temperature (C)"},{"path":"/Alarms/LowVoltage","type":"enum","name":"Low voltage alarm","enum":{"0":"No alarm","2":"Alarm"}},{"path":"/Alarms/HighVoltage","type":"enum","name":"High voltage alarm","enum":{"0":"No alarm","2":"Alarm"}},{"path":"/Alarms/LowTemperature","type":"enum","name":"Low battery temperature alarm","enum":{"0":"No alarm","2":"Alarm"}},{"path":"/Alarms/HighTemperature","type":"enum","name":"High battery temperature alarm","enum":{"0":"No alarm","2":"Alarm"}},{"path":"/Soh","type":"float","name":"State of health (%)"},{"path":"/Info/MaxChargeVoltage","type":"float","name":"CVL - Charge Voltage Limit (V)"},{"path":"/Info/MaxChargeCurrent","type":"float","name":"CCL - Charge Current Limit (A)"},{"path":"/Info/MaxDischargeCurrent","type":"float","name":"DCL - Discharge Current Limit (A)"},{"path":"/Alarms/CellImbalance","type":"enum","name":"Cell Imbalance alarm","enum":{"0":"No alarm","1":"Warning","2":"Alarm"}},{"path":"/Alarms/HighChargeCurrent","type":"enum","name":"High charge current alarm","enum":{"0":"No alarm","1":"Warning","2":"Alarm"}},{"path":"/Alarms/HighDischargeCurrent","type":"enum","name":"High discharge current alarm","enum":{"0":"No alarm","1":"Warning","2":"Alarm"}},{"path":"/Alarms/InternalFailure","type":"enum","name":"Internal error alarm","enum":{"0":"No alarm","1":"Warning","2":"Alarm"}},{"path":"/Alarms/HighChargeTemperature","type":"enum","name":"High charge temperature alarm","enum":{"0":"No alarm","1":"Warning","2":"Alarm"}},{"path":"/Alarms/LowChargeTemperature","type":"enum","name":"Low charge temperature alarm","enum":{"0":"No alarm","1":"Warning","2":"Alarm"}},{"path":"/Dc/0/Power","type":"float","name":"Battery power (W)"}]},"pathObj":{"path":"/Soc","type":"float","name":"State of charge (%)"},"name":"","x":190,"y":360,"wires":[["395f055e.546bda"]]},{"id":"c9d80104.b3654","type":"victron-input-battery","z":"3641ab29.985114","service":"com.victronenergy.battery.socketcan_can0","path":"/Dc/0/Temperature","serviceObj":{"service":"com.victronenergy.battery.socketcan_can0","name":"SIMP BMS","paths":[{"path":"/Dc/0/Voltage","type":"float","name":"Battery voltage (V)"},{"path":"/Dc/0/Current","type":"float","name":"Current (A)"},{"path":"/Soc","type":"float","name":"State of charge (%)"},{"path":"/Dc/0/Temperature","type":"float","name":"Battery temperature (C)"},{"path":"/Alarms/LowVoltage","type":"enum","name":"Low voltage alarm","enum":{"0":"No alarm","2":"Alarm"}},{"path":"/Alarms/HighVoltage","type":"enum","name":"High voltage alarm","enum":{"0":"No alarm","2":"Alarm"}},{"path":"/Alarms/LowTemperature","type":"enum","name":"Low battery temperature alarm","enum":{"0":"No alarm","2":"Alarm"}},{"path":"/Alarms/HighTemperature","type":"enum","name":"High battery temperature alarm","enum":{"0":"No alarm","2":"Alarm"}},{"path":"/Soh","type":"float","name":"State of health (%)"},{"path":"/Info/MaxChargeVoltage","type":"float","name":"CVL - Charge Voltage Limit (V)"},{"path":"/Info/MaxChargeCurrent","type":"float","name":"CCL - Charge Current Limit (A)"},{"path":"/Info/MaxDischargeCurrent","type":"float","name":"DCL - Discharge Current Limit (A)"},{"path":"/Alarms/CellImbalance","type":"enum","name":"Cell Imbalance alarm","enum":{"0":"No alarm","1":"Warning","2":"Alarm"}},{"path":"/Alarms/HighChargeCurrent","type":"enum","name":"High charge current alarm","enum":{"0":"No alarm","1":"Warning","2":"Alarm"}},{"path":"/Alarms/HighDischargeCurrent","type":"enum","name":"High discharge current alarm","enum":{"0":"No alarm","1":"Warning","2":"Alarm"}},{"path":"/Alarms/InternalFailure","type":"enum","name":"Internal error alarm","enum":{"0":"No alarm","1":"Warning","2":"Alarm"}},{"path":"/Alarms/HighChargeTemperature","type":"enum","name":"High charge temperature alarm","enum":{"0":"No alarm","1":"Warning","2":"Alarm"}},{"path":"/Alarms/LowChargeTemperature","type":"enum","name":"Low charge temperature alarm","enum":{"0":"No alarm","1":"Warning","2":"Alarm"}},{"path":"/Dc/0/Power","type":"float","name":"Battery power (W)"}]},"pathObj":{"path":"/Dc/0/Temperature","type":"float","name":"Battery temperature (C)"},"name":"","x":200,"y":420,"wires":[["dee506d2.14cde8"]]},{"id":"2ea3fb57.7fcfc4","type":"victron-input-battery","z":"3641ab29.985114","service":"com.victronenergy.battery.socketcan_can0","path":"/Dc/0/Power","serviceObj":{"service":"com.victronenergy.battery.socketcan_can0","name":"SIMP BMS","paths":[{"path":"/Dc/0/Voltage","type":"float","name":"Battery voltage (V)"},{"path":"/Dc/0/Current","type":"float","name":"Current (A)"},{"path":"/Soc","type":"float","name":"State of charge (%)"},{"path":"/Dc/0/Temperature","type":"float","name":"Battery temperature (C)"},{"path":"/Alarms/LowVoltage","type":"enum","name":"Low voltage alarm","enum":{"0":"No alarm","2":"Alarm"}},{"path":"/Alarms/HighVoltage","type":"enum","name":"High voltage alarm","enum":{"0":"No alarm","2":"Alarm"}},{"path":"/Alarms/LowTemperature","type":"enum","name":"Low battery temperature alarm","enum":{"0":"No alarm","2":"Alarm"}},{"path":"/Alarms/HighTemperature","type":"enum","name":"High battery temperature alarm","enum":{"0":"No alarm","2":"Alarm"}},{"path":"/Soh","type":"float","name":"State of health (%)"},{"path":"/Info/MaxChargeVoltage","type":"float","name":"CVL - Charge Voltage Limit (V)"},{"path":"/Info/MaxChargeCurrent","type":"float","name":"CCL - Charge Current Limit (A)"},{"path":"/Info/MaxDischargeCurrent","type":"float","name":"DCL - Discharge Current Limit (A)"},{"path":"/Alarms/CellImbalance","type":"enum","name":"Cell Imbalance alarm","enum":{"0":"No alarm","1":"Warning","2":"Alarm"}},{"path":"/Alarms/HighChargeCurrent","type":"enum","name":"High charge current alarm","enum":{"0":"No alarm","1":"Warning","2":"Alarm"}},{"path":"/Alarms/HighDischargeCurrent","type":"enum","name":"High discharge current alarm","enum":{"0":"No alarm","1":"Warning","2":"Alarm"}},{"path":"/Alarms/InternalFailure","type":"enum","name":"Internal error alarm","enum":{"0":"No alarm","1":"Warning","2":"Alarm"}},{"path":"/Alarms/HighChargeTemperature","type":"enum","name":"High charge temperature alarm","enum":{"0":"No alarm","1":"Warning","2":"Alarm"}},{"path":"/Alarms/LowChargeTemperature","type":"enum","name":"Low charge temperature alarm","enum":{"0":"No alarm","1":"Warning","2":"Alarm"}},{"path":"/Dc/0/Power","type":"float","name":"Battery power (W)"}]},"pathObj":{"path":"/Dc/0/Power","type":"float","name":"Battery power (W)"},"name":"","x":190,"y":480,"wires":[["769bb4c8.25cbbc"]]},{"id":"61d8c7f4.833fe8","type":"ui_group","name":"BMS Data","tab":"efc2e19b.ce45a","order":1,"disp":true,"width":"6","collapse":false},{"id":"60346d2e.382554","type":"mqtt-broker","name":"DrBus","broker":"172.16.14.10","port":"1883","clientid":"","usetls":false,"compatmode":false,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""},{"id":"f8656422.5ed208","type":"ui_group","name":"Manual Control","tab":"efc2e19b.ce45a","order":2,"disp":true,"width":"6","collapse":false},{"id":"6311a09c.95026","type":"mqtt-broker","name":"Mosquitto","broker":"127.0.0.1","port":"1883","clientid":"NodeRed On Pi","usetls":false,"compatmode":false,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""},{"id":"efc2e19b.ce45a","type":"ui_tab","name":"Inverter BMS ","icon":"dashboard","order":2,"disabled":false,"hidden":false}]
What exactly is the problem that you are having? If you uninstalled the victron node and still have the nodes in the flow then when you start node-red it will hang saying there are missing nodes.
No it warns you of the missing Victron nodes and then takes you into the full editor environment where you can make then changes. If push comes to shove I could load the Victron nodes again and the functionality would be restored. However that would return to the original problem of locking you out of the editing environment.
In my case I have chosen to run the Victron nodes on a Raspberry Pi that I haven't updated yet and pass data to and from via MQTT.
Actually I have notice a big improvement in responsiveness by having two RPI's. One handling logic and the other handling the web GUI with MQTT as the interface between the two.
Well this is very odd, I am seeing something similar. Even after removing the victron nodes and all references (including checking for configuration nodes) when I restart node-red it hangs when loading the editor. When I look in my flows file I see
        "id": "victron-client-id",
        "type": "victron-client"
If I delete that bit of the file (make a backup first and then make sure you delete it including the comma on the end, then restart node-red all is well. But a bit later after some more deploys that section has come back again. So the short term workaround is to delete that, but I haven't worked out why it keeps coming back.
What version of node-red are you running? You can see it at the bottom of the hamburger menu dropdown.
I see what I had done, I had not properly uninstalled the victron nodes. That is why it kept coming back.
There is definitely an issue with the victron node causing it to hang on reloading the editor, but if you uninstall the victron node and restart node red and refresh the browser then it tells you there are missing nodes and you can remove them.
So I think you will just have to wait for a response from the node author.
