Very odd, I just noticed that my Node-RED crashed after running since the 22nd (see attached log) I wasn't even using NR at the time. The last time I did a deploy was about 27 hours before this happened.
192.168.48.99 is the address of my Mac where NR was running. I do a lot of experimenting (and adding in other's flows to see if I can help them) on the Mac.
Any idea's?
Log (shortened)
Welcome to Node-RED
22 Dec 23:50:23 - [info] Node-RED version: v0.19.5
22 Dec 23:50:23 - [info] Node.js version: v8.9.4
22 Dec 23:50:23 - [info] Darwin 17.7.0 x64 LE
22 Dec 23:50:23 - [info] Loading palette nodes
22 Dec 23:50:24 - [warn] rpi-gpio : Raspberry Pi specific node set inactive
22 Dec 23:50:25 - [warn] [chart request] Deprecated call to RED.runtime.nodes.registerType - node-set name must be provided as first argument
22 Dec 23:50:25 - [warn] [chart response] Deprecated call to RED.runtime.nodes.registerType - node-set name must be provided as first argument
22 Dec 23:50:26 - [info] Dashboard version 2.10.1 started at /ui
22 Dec 23:50:26 - [info] Settings file : /Users/Paul/.node-red/settings.js
22 Dec 23:50:26 - [info] Context store : 'default' [module=localfilesystem]
22 Dec 23:50:26 - [info] Context store : 'memoryOnly' [module=memory]
22 Dec 23:50:26 - [info] User directory : /Users/Paul/.node-red
22 Dec 23:50:26 - [warn] Projects disabled : editorTheme.projects.enabled=false
22 Dec 23:50:26 - [info] Flows file : /Users/Paul/.node-red/david2.json
22 Dec 23:50:26 - [info] Server now running at http://127.0.0.1:1880/
your credentials.
22 Dec 23:50:26 - [info] Starting flows
22 Dec 23:50:27 - [info] Started flows
22 Dec 23:50:27 - [info] [sqlitedb:c5303ee9.6aadf8] opened /Users/Paul/sqlite_dbs/pmwsqlitedb ok
<...snip...>
26 Dec 05:25:24 - [info] [mqtt-broker:86799c21.0a2a18] Connected to broker: mqtt://192.168.48.100:1883
26 Dec 05:27:37 - [info] [mqtt-broker:a50210ee.e688e8] Disconnected from broker: mqtt://192.168.48.100:1883
26 Dec 05:27:37 - [info] [mqtt-broker:e4b6ece0.98a758] Disconnected from broker: mqtt://plantpi.local:1883
26 Dec 05:27:52 - [info] [mqtt-broker:a50210ee.e688e8] Connected to broker: mqtt://192.168.48.100:1883
26 Dec 05:27:52 - [info] [mqtt-broker:e4b6ece0.98a758] Connected to broker: mqtt://plantpi.local:1883
26 Dec 06:04:00 - [red] Uncaught Exception:
26 Dec 06:04:00 - Error: bind EADDRNOTAVAIL 192.168.48.99:50086
at Object._errnoException (util.js:1022:11)
at _exceptionWithHostPort (util.js:1044:20)
at _handle.lookup (dgram.js:266:18)
at _combinedTickCallback (internal/process/next_tick.js:141:11)
at process._tickCallback (internal/process/next_tick.js:180:9)
Pauls-mini:~ Paul$
