I just updated Node-RED container, I was able to send videos got by my camera in Home Assistant in the previous build 2.x, now with this update, whenever I try to send videos with my telegram bot it says that
Caught exception in sender node:
Error: EFATAL: Unsupported Buffer file-type
when processing message:
{"_msgid":“d092c532152ec973”,“payload”:{“type”:“video”,“chatId”:“XXXX”,“content”:{“type”:“Buffer”,“data”:[0,0,0,3…
I have tried many solutions:
I tried to install
npm install bufferutil utf-8-validate
I tried to update npm and node, these are my versions:
I did, the only problem is with video, the bot is working for other media, pictures work fine for example. I found a solution that uses HA to communicate to the telegram bot and then send the video using HA service instead of the native node red, but I think that's not the optimal way, the TB is configured only in node red and was working fine before, worst case scenario would be to revert to 2.x, I just did it for this year version whereas the problem on that thread seems to be for 2019. The TB is configured with the node-red-contrib-telegrambot.
