Error ERR_OUT_OF_RANGE
I have this error in syslog and I can't find how to fix it.
Can you help me?
*Jan  6 14:44:21 iot2050[298]: 6 Jan 14:44:21 - [red] Uncaught Exception:*
*Jan  6 14:44:21 iot2050[298]: 6 Jan 14:44:21 - RangeError [ERR_OUT_OF_RANGE]: The value of "offset" is out of range. It must be >= 0 and <= 7. Received 9*
*Jan  6 14:44:21 iot2050[298]:     at boundsError (internal/buffer.js:82:9)*
*Jan  6 14:44:21 iot2050[298]:     at Buffer.readUInt16BE (internal/buffer.js:328:5)*
*Jan  6 14:44:21 iot2050[298]:     at _readFC4 (/root/.node-red/node_modules/modbus-serial/index.js:118:24)*
*Jan  6 14:44:21 iot2050[298]:     at ModbusRTU._onReceive (/root/.node-red/node_modules/modbus-serial/index.js:427:13)*
*Jan  6 14:44:21 iot2050[298]:     at TcpPort.emit (events.js:314:20)*
*Jan  6 14:44:21 iot2050[298]:     at Socket.<anonymous> (/root/.node-red/node_modules/modbus-serial/ports/tcpport.js:92:20)*
*Jan  6 14:44:21 iot2050[298]:     at Socket.emit (events.js:314:20)*
*Jan  6 14:44:21 iot2050[298]:     at addChunk (_stream_readable.js:297:12)*
*Jan  6 14:44:21 iot2050[298]:     at readableAddChunk (_stream_readable.js:272:9)*
*Jan  6 14:44:21 iot2050d[298]:     at Socket.Readable.push (_stream_readable.js:213:10)*
*Jan  6 14:44:21 iot2050 systemd[1]: node-red.service: Main process exited, code=exited, status=1/FAILURE*
*Jan  6 14:44:21 iot2050 systemd[1]: node-red.service: Failed with result 'exit-code'.*
*Jan  6 14:44:21 iot2050 systemd[1]: node-red.service: Consumed 19min 53.911s CPU time.*
How can I find out where in the program this error is coming from? at boundsError (internal/buffer.js:82:9)
Thank you.
You are using Modbus and somewhere in your flow it looks like you are receiving an input over modbus-serial that is outside of the allowed range. So I'd start by looking at your modbus flows.
Hello TotallyInformation
Thank you for your answer.
Yes, we think the problem is about the modbus tcp flows. We don't find the solution yet. When we know, I will post it.
