Error: getaddrinfo ENOTFOUND http http:80
Hola chicos,
Quiero guardar los datos que recoge mi sensor de temperatura y guardarlos en influxdb a través de MQTT, MOSQUITTO, NODERED, INFLUXDB y representarlo en GRAFANA. El problema es que el nodo de INFLUXDB en NODERED da éste error.
4
ThankYou
Sorry, most of us speak English I'm afraid. My Spanish is especially poor!
However, you would need to provide more context to let us understand what is going on.
translate.google.com translates the OP's post as
Hi guys,
I want to save the data collected by my temperature sensor and save them in influxdb through MQTT, MOSQUITTO, NODERED, INFLUXDB and represent it in GRAFANA. The problem is that the INFLUXDB node in NODERED gives this error.
@Barkalez
Revisaría su instalación de INFLUXDB - parece que no proporcionó la dirección IP que apunta a las afluencias
translation:
I would review your installation of INFLUXDB - it looks like you did not provide the IP address pointing at influxdb
It looks like the influxdb node is not correctly configured, show us what settings you have for the node and for the server node that you have setup.
