Error in installation of arduino/node-red-contrib-arduino-iot-cloud in node-red
I am facing a problem when installing the "node-red-contrib-arduino-iot-cloud" in the "manege palette" or via CMD of Node-Red. Whenever I try to install through the graphical interface it throws the following error:
versions:-
Node-RED version: v2.2.2
10 Jul 18:50:13 - [info] Node.js version: v16.16.0
10 Jul 18:50:13 - [info] Windows_NT 10.0.19044 x64 LE
error
C:\Users\homepc.node-red>npm install @arduino/node-red-contrib-arduino-iot-cloud
npm WARN config global --global, --local are deprecated. Use --location=global instead.
npm ERR! code ENOENT
npm ERR! syscall spawn git
npm ERR! path git
npm ERR! errno -4058
npm ERR! enoent An unknown git error occurred
npm ERR! enoent This is related to npm not being able to find a file.
npm ERR! enoent
Check the log for more information "
If anyone can help me, thank you very much.
585 http fetch GET 200 https://registry.npmjs.org/mime-types 36ms (cache miss)
586 http fetch GET 200 https://registry.npmjs.org/lru-cache 37ms (cache miss)
587 http fetch GET 200 https://registry.npmjs.org/asynckit 46ms (cache miss)
588 http fetch GET 200 https://registry.npmjs.org/combined-stream 52ms (cache miss)
589 http fetch GET 200 https://registry.npmjs.org/side-channel 51ms (cache miss)
590 timing idealTree:node_modules/superagent Completed in 70ms
591 timing idealTree:node_modules/component-emitter Completed in 0ms
592 timing idealTree:node_modules/cookiejar Completed in 0ms
593 timing idealTree:node_modules/fast-safe-stringify Completed in 0ms
594 silly placeDep ROOT asynckit@0.4.0 OK for: form-data@3.0.1 want: ^0.4.0
595 silly placeDep ROOT combined-stream@1.0.8 OK for: form-data@3.0.1 want: ^1.0.8
596 silly placeDep ROOT mime-types@2.1.35 OK for: form-data@3.0.1 want: ^2.1.12
597 silly fetch manifest delayed-stream@~1.0.0
598 silly fetch manifest mime-db@1.52.0
599 http fetch GET 200 https://registry.npmjs.org/delayed-stream 43ms (cache miss)
600 http fetch GET 200 https://registry.npmjs.org/mime-db 43ms (cache miss)
601 timing idealTree:node_modules/form-data Completed in 48ms
602 timing idealTree:node_modules/asynckit Completed in 0ms
603 silly placeDep ROOT delayed-stream@1.0.0 OK for: combined-stream@1.0.8 want: ~1.0.0
604 timing idealTree:node_modules/combined-stream Completed in 1ms
605 timing idealTree:node_modules/delayed-stream Completed in 0ms
606 timing idealTree:node_modules/formidable Completed in 0ms
607 timing idealTree:node_modules/methods Completed in 0ms
608 timing idealTree:node_modules/mime Completed in 0ms
609 silly placeDep ROOT mime-db@1.52.0 OK for: mime-types@2.1.35 want: 1.52.0
610 timing idealTree:node_modules/mime-types Completed in 1ms
611 timing idealTree:node_modules/mime-db Completed in 0ms
612 silly placeDep ROOT side-channel@1.0.4 OK for: qs@6.11.0 want: ^1.0.4
613 silly fetch manifest call-bind@^1.0.0
614 silly fetch manifest get-intrinsic@^1.0.2
615 silly fetch manifest object-inspect@^1.9.0
616 http fetch GET 200 https://registry.npmjs.org/call-bind 44ms (cache miss)
617 http fetch GET 200 https://registry.npmjs.org/object-inspect 43ms (cache miss)
618 http fetch GET 200 https://registry.npmjs.org/get-intrinsic 63ms (cache miss)
619 timing idealTree:node_modules/qs Completed in 66ms
620 silly placeDep ROOT call-bind@1.0.2 OK for: side-channel@1.0.4 want: ^1.0.0
621 silly placeDep ROOT get-intrinsic@1.1.2 OK for: side-channel@1.0.4 want: ^1.0.2
622 silly placeDep ROOT object-inspect@1.12.2 OK for: side-channel@1.0.4 want: ^1.9.0
623 silly fetch manifest function-bind@^1.1.1
624 silly fetch manifest has@^1.0.3
625 silly fetch manifest has-symbols@^1.0.3
626 http fetch GET 200 https://registry.npmjs.org/has-symbols 30ms (cache miss)
627 http fetch GET 200 https://registry.npmjs.org/has 44ms (cache miss)
628 http fetch GET 200 https://registry.npmjs.org/function-bind 47ms (cache miss)
629 timing idealTree:node_modules/side-channel Completed in 50ms
630 silly placeDep ROOT function-bind@1.1.1 OK for: call-bind@1.0.2 want: ^1.1.1
631 timing idealTree:node_modules/call-bind Completed in 2ms
632 timing idealTree:node_modules/function-bind Completed in 0ms
633 silly placeDep ROOT has@1.0.3 OK for: get-intrinsic@1.1.2 want: ^1.0.3
634 silly placeDep ROOT has-symbols@1.0.3 OK for: get-intrinsic@1.1.2 want: ^1.0.3
635 timing idealTree:node_modules/get-intrinsic Completed in 2ms
636 timing idealTree:node_modules/has Completed in 0ms
637 timing idealTree:node_modules/has-symbols Completed in 0ms
638 timing idealTree:node_modules/object-inspect Completed in 0ms
639 silly placeDep ROOT has-flag@3.0.0 OK for: supports-color@5.5.0 want: ^3.0.0
640 timing idealTree:node_modules/supports-color Completed in 1ms
641 timing idealTree:node_modules/has-flag Completed in 0ms
642 timing idealTree:node_modules/through2 Completed in 0ms
643 silly placeDep ROOT is-absolute@1.0.0 OK for: to-absolute-glob@2.0.2 want: ^1.0.0
644 silly fetch manifest is-relative@^1.0.0
645 silly fetch manifest is-windows@^1.0.1
646 http fetch GET 200 https://registry.npmjs.org/is-windows 37ms (cache miss)
647 http fetch GET 200 https://registry.npmjs.org/is-relative 1098ms (cache miss)
648 timing idealTree:node_modules/to-absolute-glob Completed in 1100ms
649 silly placeDep ROOT is-relative@1.0.0 OK for: is-absolute@1.0.0 want: ^1.0.0
650 silly placeDep ROOT is-windows@1.0.2 OK for: is-absolute@1.0.0 want: ^1.0.1
651 silly fetch manifest is-unc-path@^1.0.0
652 http fetch GET 200 https://registry.npmjs.org/is-unc-path 81ms (cache miss)
653 timing idealTree:node_modules/is-absolute Completed in 90ms
654 silly placeDep ROOT is-unc-path@1.0.0 OK for: is-relative@1.0.0 want: ^1.0.0
655 silly fetch manifest unc-path-regex@^0.1.2
656 http fetch GET 200 https://registry.npmjs.org/unc-path-regex 89ms (cache miss)
657 timing idealTree:node_modules/is-relative Completed in 96ms
658 silly placeDep ROOT unc-path-regex@0.1.2 OK for: is-unc-path@1.0.0 want: ^0.1.2
659 timing idealTree:node_modules/is-unc-path Completed in 3ms
660 timing idealTree:node_modules/is-windows Completed in 0ms
661 timing idealTree:node_modules/to-fast-properties Completed in 0ms
662 silly placeDep ROOT is-number@7.0.0 OK for: to-regex-range@5.0.1 want: ^7.0.0
663 timing idealTree:node_modules/to-regex-range Completed in 3ms
664 timing idealTree:node_modules/is-number Completed in 1ms
665 timing idealTree:node_modules/type Completed in 0ms
666 timing idealTree:node_modules/typedarray Completed in 0ms
667 timing idealTree:node_modules/unc-path-regex Completed in 0ms
668 silly placeDep ROOT json-stable-stringify-without-jsonify@1.0.1 OK for: unique-stream@2.3.1 want: ^1.0.1
669 silly placeDep ROOT through2-filter@3.0.0 OK for: unique-stream@2.3.1 want: ^3.0.0
670 timing idealTree:node_modules/unique-stream Completed in 8ms
671 timing idealTree:node_modules/json-stable-stringify-without-jsonify Completed in 0ms
672 timing idealTree:node_modules/through2-filter Completed in 0ms
673 silly placeDep ROOT escalade@3.1.1 OK for: update-browserslist-db@1.0.4 want: ^3.1.1
674 silly placeDep ROOT picocolors@1.0.0 OK for: update-browserslist-db@1.0.4 want: ^1.0.0
675 timing idealTree:node_modules/update-browserslist-db Completed in 4ms
676 timing idealTree:node_modules/escalade Completed in 0ms
677 timing idealTree:node_modules/picocolors Completed in 0ms
678 silly placeDep ROOT ws@3.3.3 OK for: websocket-stream@5.5.2 want: ^3.2.0
679 silly fetch manifest async-limiter@~1.0.0
680 silly fetch manifest ultron@~1.1.0
681 http fetch GET 200 https://registry.npmjs.org/async-limiter 35ms (cache miss)
682 http fetch GET 200 https://registry.npmjs.org/ultron 5428ms (cache miss)
683 timing idealTree:node_modules/websocket-stream Completed in 5433ms
684 silly placeDep ROOT async-limiter@1.0.1 OK for: ws@3.3.3 want: ~1.0.0
685 silly placeDep ROOT ultron@1.1.1 OK for: ws@3.3.3 want: ~1.1.0
686 timing idealTree:node_modules/ws Completed in 13ms
687 timing idealTree:node_modules/async-limiter Completed in 0ms
688 timing idealTree:node_modules/ultron Completed in 0ms
689 timing idealTree:node_modules/xtend Completed in 0ms
690 silly placeDep node_modules/@arduino/arduino-iot-client debug@3.2.7 OK for: superagent@3.7.0 want: ^3.1.0
691 silly placeDep node_modules/@arduino/arduino-iot-client form-data@2.5.1 OK for: superagent@3.7.0 want: ^2.3.1
692 silly placeDep node_modules/@arduino/arduino-iot-client mime@1.6.0 OK for: superagent@3.7.0 want: ^1.4.1
693 timing idealTree:node_modules/@arduino/arduino-iot-client/node_modules/superagent Completed in 23ms
694 timing idealTree:node_modules/@arduino/arduino-iot-client/node_modules/debug Completed in 0ms
695 timing idealTree:node_modules/@arduino/arduino-iot-client/node_modules/form-data Completed in 0ms
696 timing idealTree:node_modules/@arduino/arduino-iot-client/node_modules/mime Completed in 0ms
697 timing idealTree:node_modules/@arduino/node-red-contrib-arduino-iot-cloud/node_modules/@arduino/cbor-js Completed in 0ms
698 timing idealTree:node_modules/@babel/core/node_modules/semver Completed in 0ms
699 timing idealTree:node_modules/@babel/generator/node_modules/@jridgewell/gen-mapping Completed in 0ms
700 timing idealTree:node_modules/@babel/helper-compilation-targets/node_modules/semver Completed in 0ms
701 timing idealTree:node_modules/es6-set/node_modules/es6-symbol Completed in 0ms
702 timing idealTree:node_modules/ext/node_modules/type Completed in 0ms
703 silly placeDep node_modules/glob-stream is-glob@3.1.0 OK for: glob-parent@3.1.0 want: ^3.1.0
704 silly placeDep ROOT path-dirname@1.0.2 OK for: glob-parent@3.1.0 want: ^1.0.0
705 timing idealTree:node_modules/glob-stream/node_modules/glob-parent Completed in 2ms
706 timing idealTree:node_modules/path-dirname Completed in 0ms
707 timing idealTree:node_modules/glob-stream/node_modules/is-glob Completed in 0ms
708 timing idealTree:node_modules/pumpify/node_modules/pump Completed in 0ms
709 timing idealTree:node_modules/split2/node_modules/readable-stream Completed in 0ms
710 timing idealTree:node_modules/superagent/node_modules/readable-stream Completed in 0ms
711 silly placeDep ROOT lru-cache@6.0.0 OK for: semver@7.3.7 want: ^6.0.0
712 silly fetch manifest yallist@^4.0.0
713 http fetch GET 200 https://registry.npmjs.org/yallist 45ms (cache miss)
714 timing idealTree:node_modules/superagent/node_modules/semver Completed in 48ms
715 silly placeDep ROOT yallist@4.0.0 OK for: lru-cache@6.0.0 want: ^4.0.0
716 timing idealTree:node_modules/lru-cache Completed in 1ms
717 timing idealTree:node_modules/yallist Completed in 0ms
718 timing idealTree:buildDeps Completed in 17422ms
719 timing idealTree:fixDepFlags Completed in 2ms
720 timing idealTree Completed in 17496ms
721 timing command:install Completed in 17508ms
722 verbose stack Error: An unknown git error occurred
722 verbose stack     at makeError (C:\Program Files\nodejs\node_modules\npm\node_modules\@npmcli\git\lib\make-error.js:28:13)
722 verbose stack     at C:\Program Files\nodejs\node_modules\npm\node_modules\@npmcli\git\lib\spawn.js:37:26
722 verbose stack     at processTicksAndRejections (node:internal/process/task_queues:96:5)
723 verbose cwd C:\Users\homepc\.node-red
724 verbose Windows_NT 10.0.19044
725 verbose node v16.16.0
726 verbose npm  v8.11.0
727 error code ENOENT
728 error syscall spawn git
729 error path git
730 error errno -4058
731 error enoent An unknown git error occurred
732 error enoent This is related to npm not being able to find a file.
732 error enoent
733 verbose exit -4058
734 timing npm Completed in 17661ms
735 verbose unfinished npm timer reify 1657462908232
736 verbose unfinished npm timer reify:loadTrees 1657462908242
737 verbose code -4058
738 error A complete log of this run can be found in:
738 error     C:\Users\homepc\AppData\Local\npm-cache\_logs\2022-07-10T14_21_48_084Z-debug-0.log
I think that is saying that you need to install git. The instructions for installing the node on its home page should say that though, which it doesn't. I suggest installing git and trying again.
Thanks Colin, I installed GIT but still getting the same error
11 Jul 09:23:52 - [info] Server now running at http://127.0.0.1:1880/
11 Jul 09:23:52 - [info] Starting flows
11 Jul 09:23:52 - [info] Started flows
11 Jul 09:24:28 - [info] Installing module: @arduino/node-red-contrib-arduino-iot-cloud, version: 1.0.7
11 Jul 09:25:00 - [warn] Installation of module @arduino/node-red-contrib-arduino-iot-cloud failed:
11 Jul 09:25:00 - [warn] ------------------------------------------
11 Jul 09:25:00 - [warn] npm WARN config global --global, --local are deprecated. Use --location=global instead.
npm WARN config production Use --omit=dev instead.
npm ERR! path git
npm ERR! enoent
npm ERR! C:\Users\homepc\AppData\Local\npm-cache_logs\2022-07-11T03_54_30_140Z-debug-0.log
Error: Install failed
at C:\Users\homepc\AppData\Roaming\npm\node_modules\node-red\node_modules@node-red\registry\lib\installer.js:285:25 at processTicksAndRejections (node:internal/process/task_queues:96:5)
11 Jul 09:25:00 - [error] Error: Install failed
Are you able to install other modules ok?
If so then please try installing it in a terminal window, go into your .node-red directory and run
and post the full output here, including the line showing the install command. Hopefully that will give us a clue. Probably worth rebooting first.
Thanks a lot Colin, its working now after restart and hopefully also after installation of git.
