Hi! Can someone help me with codesys vs node red?
I get some errors about the endpoint!
I try with 192.196……. and 127.0….. my local host.
When I will inject the debug don’t accept this?
What to do? Please someone.
Did you look in the console? Are you getting any error?
You really need to provide more information if you want help.
- what do you mean by
help me with codesys vs node red?Are you comparing the two? - what errors are you getting?
- can you reproduce the issue with a small example flow?
- what version of NR and node.js are you running?
Please open a terminal window and stop then start Node-RED. Then run your test. After the problem occurs go back to the terminal window and copy everything from when you started NR to when the problem occurs and paste it in a reply (see below)
Export the sample flow and paste it to a reply.
In order to make code readable and usable it is necessary to surround your code with three backticks (also known as a left quote or backquote ```)
code goes here
You can edit and correct your post by clicking the pencil
icon.
