Hi All,
I have executed a python script (taken locally) using a python shell node in node-red. What is the command can be used in exec to stop running infinity loop??
Can anyone help me??
Hi, are you the same user as Sandy?
This thread is ALMOST identical to one less than a page down in the forum...
You can't use the exec node to kill the pythonshell node, you have to use the exec node to run the python script, instead of using the pythonshell node. Then when it is running you can kill the exec node if necessary.
Is this a college assignment or similar since you both seem to be working on similar projects?
