EXEC Node and ./e3dcset
Good evening,
i am a newbie to node-red trying to use EXEC-Node to start a program.
simple run /home/e3dcset/e3dcset does not work
changing directory to /home/e3dcset and simple type e3dcset does not work
i need to start on CLI using: ./e3dcset
how to start via Node-Red EXEC ?
greetings michael
Welcome to the forum @dancekid
What command do you use, from what folder, to run it in a command window?
What hardware and os are you running on? Are you using docker or home assistant or anything similar?
Hello Colin,
got support from iobroker forum.
needed CLI-Start ./e3dcset
solution in node-red: cd /home/e3dcset && ./e3dcset
just needed to join both into one command.
