Execute fswebcam running Node Red in Docker
I have a problem using the exec node.
Maybe I miss something fundamental. Any Information might help.
The goal was to use a command like this:
fswebcam --rotate 270 /home/pi/nodehttpd/image.jpg
Node Red is started in a Docker container via Docker-Compose.
  nodered:
    container_name: nodered
    build: ./services/nodered/.
    privileged: true
    restart: unless-stopped
    user: "1000"
    ports:
      - 1880:1880
    volumes:
      - ./volumes/nodered/data:/data
"fswebcam" is installed on the host.
I cannot executed it, even with a shell script in the shares /data folder. direct paths etc tested.
Debug : "command not found"
Any suggestions?
Did you try giving the full path to the command ?
Yes,
in the exec node I also tried:
/usr/bin/fswebcam --rotate 270 /home/pi/nodehttpd/image.jpg
I also tried it with a simple bash script in the data folder (getpic.sh), containing the commands above
exec command then was:
bash /data/getpc.sh
the container has it's own isolated file system (that is kind of the point :-). so you would need to either ssh back out of the container to the host - or mount (or maybe alias) the command into the mounted volume (but then it may not have access to all the required libraries (if any are needed))
Thank you for help, dceejay.
As workaround I use a node.js script as webserver now.
calling it by http://IPADDRESS:8888/
var http = require("http");
const exec = require("child_process").exec;
function onRequest(request, res) {
  console.log("Request received.");
  var child = exec('bash /home/pi/campic.sh', function(err, stdout, stderr) {
            console.log(stdout);
            console.log(stderr);
            if (err !== null) {
                console.log(`exec error: ${err}`);
http.createServer(onRequest).listen(8888, function () {
  console.log("Server has started.");
If someone has a better idea, please let me know.
Do you have a better way?
You've opened your own thread so closing this one
