Exec node creating two processes
Hi guys,
Im trying to place a switch to on/off my rPI => twitch.tv stream. The flow:
[{"id":"bcea7856.3d9df8","type":"tab","label":"Flow 1","disabled":false,"info":""},{"id":"32b7b5b1.ee028a","type":"toggle","z":"bcea7856.3d9df8","name":"","onOffTopic":"","onValue":"true","onType":"bool","offValue":"false","offType":"bool","toggleTopic":"","toggleValue":"","toggleType":"str","passOnOff":"always","x":390,"y":100,"wires":[["aabe67a3.1a63a8"]]},{"id":"496b7ee3.9a249","type":"ui_switch","z":"bcea7856.3d9df8","name":"twitch button","label":"Twitch.tv","tooltip":"","group":"a281b975.ebda78","order":2,"width":0,"height":0,"passthru":true,"decouple":"false","topic":"topic","topicType":"msg","style":"","onvalue":"true","onvalueType":"bool","onicon":"","oncolor":"","offvalue":"false","offvalueType":"bool","officon":"","offcolor":"","animate":false,"x":150,"y":100,"wires":[["32b7b5b1.ee028a"]]},{"id":"aabe67a3.1a63a8","type":"switch","z":"bcea7856.3d9df8","name":"","property":"payload","propertyType":"msg","rules":[{"t":"true"},{"t":"false"}],"checkall":"true","repair":false,"outputs":2,"x":570,"y":100,"wires":[["5c1b9d80.41d054"],["878cf0e2.cb56"]]},{"id":"5c1b9d80.41d054","type":"exec","z":"bcea7856.3d9df8","command":"raspivid -n -t 0 -w 1920 -h 1080 -b 3500000 -fps 30 -o - | ffmpeg -re -i - -input_format h264 -vcodec copy -an -f flv \"rtmp://mad.contribute.live-video.net/app/XXXXX\"","addpay":false,"append":"","useSpawn":"false","timer":"","oldrc":false,"name":"ffmpeg","x":820,"y":60,"wires":[[],[],[]]},{"id":"878cf0e2.cb56","type":"change","z":"bcea7856.3d9df8","name":"set to pid","rules":[{"t":"set","p":"payload","pt":"msg","to":"pid","tot":"flow"}],"action":"","property":"","from":"","to":"","reg":false,"x":820,"y":140,"wires":[["59538706.2fbb58"]]},{"id":"59538706.2fbb58","type":"exec","z":"bcea7856.3d9df8","command":"kill ","addpay":true,"append":"","useSpawn":"false","timer":"","oldrc":false,"name":"","x":970,"y":140,"wires":[[],[],[]]},{"id":"259af9f7.6627d6","type":"status","z":"bcea7856.3d9df8","name":"","scope":["5c1b9d80.41d054"],"x":140,"y":180,"wires":[["79129e0c.3eaa8"]]},{"id":"79129e0c.3eaa8","type":"function","z":"bcea7856.3d9df8","name":"get pid","func":"if(msg.status.text){\n    let pid = msg.status.text.split(':');\n    msg.payload = pid[1];\n    return msg;\n} else {\n    return null;\n}","outputs":1,"noerr":0,"initialize":"","finalize":"","x":300,"y":180,"wires":[["cbe8f9da.101a08"]]},{"id":"cbe8f9da.101a08","type":"change","z":"bcea7856.3d9df8","name":"","rules":[{"t":"set","p":"pid","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":470,"y":180,"wires":[[]]},{"id":"a281b975.ebda78","type":"ui_group","name":"MOIST","tab":"2f7ea51a.3ab7ea","order":2,"disp":true,"width":"6","collapse":false},{"id":"2f7ea51a.3ab7ea","type":"ui_tab","name":"DHT","icon":"dashboard","disabled":false,"hidden":false}]
When I run:
pi@pi2:~/twitch $ ps aux | grep raspi
pi 1662 0.4 0.2 7672 2540 ? S 00:58 0:00 /bin/bash -c raspivid -n -t 0 -w 1920 -h 1080 -b 3500000 -fps 30 -o - | ffmpeg -re -i - -input_format h264 -vcodec copy -an -f flv "rtmp://mad.contribute.live-video.net/app/XXXXX"
pi 1663 0.8 0.2 63136 1944 ? Sl 00:58 0:00 raspivid -n -t 0 -w 1920 -h 1080 -b 3500000 -fps 30 -o -
and the status node is returning only the first PID. Could you help me identify what are these two process?
One is the /bin/bash process of the shell running the command. The other is the raspivid process itself.
That's entirely normal to see.
In order to get rid of process IDs I'm thinking about to use the command as a service, then do something like:
service streaming start/stop
Do you have another better workaround? Is there any way to catch the raspivid processID itself?
