Greetings!
I have problems with my Shelly dimmer 2. I have set it up over mqtt. Everything works great except dimming slider value. Dimming slider works great when I am using it, but I wan't that slider pick up the value from shelly dimmer when it is dimmed somewhere else.
I have subscribed to MQTT topic "shellies/shellydimmer2-D8BFC01A040E/light/0/status" and when I dimm it somewhere else I get this on debug node
shellies/shellydimmer2-D8BFC01A040E/light/0/status : msg : Object
object
topic: "shellies/shellydimmer2-D8BFC01A040E/light/0/status"
payload: "{"ison":true,"has_timer":false,"timer_started":0,"timer_duration":0,"timer_remaining":0,"mode":"white","brightness":16}"
qos: 0
retain: false
_msgid: "14b5cdb.c291e32"
I would like to get only the value "brightness":16 or any other value of brightness to output as number so I can send that number to slider node.
Can someone help me?
Thank you!
