Hello, I'm trying to install the node-red-contrib-chatbot in Node_Red (IBM Watson - https: //*****.mybluemix.net/red/#flow/) and is failing as the log image below.
The problem is the same as @SoCold and @ david1223 only with another plugin. (Should I have answered there?)
Believe the problem is in the IBM Bluemix service because on Node-red localhost I did, but I need the bluemix service.
What should I do?
