Hi
I would like to write some function node using aws-sdk in my Node-RED running as a docker container (official image nodered/node-red:2.2.2-14).
I tried both
npm install aws-sdkfrom the command line (from directory/dataas user node-red) or - adding module
aws-sdkimport asAWSin the setup block of my function node
In both case I end-up with the following error log:
npm WARN deprecated querystring@0.2.0: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
npm WARN deprecated uuid@3.3.2: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
npm ERR! code ENOENT
npm ERR! syscall rename
npm ERR! path /data/node_modules/aws-sdk
npm ERR! dest /data/node_modules/.aws-sdk.DELETE
npm ERR! errno -2
npm ERR! enoent ENOENT: no such file or directory, rename '/data/node_modules/aws-sdk' -> '/data/node_modules/.aws-sdk.DELETE'
npm ERR! enoent This is related to npm not being able to find a file.
npm ERR! enoent
npm ERR! /data/.npm/_logs/2022-04-06T21_42_30_350Z-debug.log
File : 2022-04-06T21_42_30_350Z-debug.log
What am I doing wrong ?
Barbudor
