Feature request: rename a project
Is it possible to rename a NR project? I have not found a way to do this in the flow editor, and I hesitate to mess around with directory names and configuration files. If it is not possible now, would it be feasible in a future version?
Hi, any updates on this topic?
As far as I can see, the workaround exists of renaming manually in the projects directory:
  • changing folder name of the project
  • changing value of "name" field in package.json file
I had to update my key for the credentials flow.
Seemed to work after that.
It would be really nice to be able to do this via the UI. I set this up for my boss as per his request on an AWS EC2 server, and he would really like to be able to rename projects via the UI.
