Ffmpeg node - Args with Array
Open a topic to ask a simple question about the ffmpeg node by dear @kevinGodell .
I need to pass these parameters through a URL because I'm going to send this data via a global variable.
Does this node allow this change? If so, in what way ?
I've tried injecting and it's still not possible.
I solved:
[{"id":"7a8c3f95b486b8f9","type":"ffmpeg","z":"5273a6de.b59318","name":"","outputs":3,"cmdPath":"ffmpeg","cmdArgs":"[]","cmdOutputs":2,"killSignal":"SIGTERM","x":590,"y":320,"wires":[["4cc7afbbcc802243"],["4cc7afbbcc802243"],["722408a8d61866db"]]},{"id":"5654e6d653ad2b72","type":"inject","z":"5273a6de.b59318","name":"stop","props":[{"p":"action","v":"{\"command\":\"stop\"}","vt":"json"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":190,"y":400,"wires":[[]]},{"id":"3db9c9f03c8f6cae","type":"inject","z":"5273a6de.b59318","name":"start","props":[{"p":"action","v":"{\"command\":\"start\",\"args\":[\"-loglevel\",\"quiet\",\"-rtsp_transport\",\"tcp\",\"-i\",\"rtsp://belov:belov12345678@192.168.1.129:554/cam/realmonitor?channel=1&subtype=0\",\"-an\",\"-c:v\",\"copy\",\"-f\",\"mp4\",\"-movflags\",\"+frag_every_frame+empty_moov+default_base_moof\",\"-min_frag_duration\",\"1000000\",\"pipe:1\"]}","vt":"json"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":190,"y":460,"wires":[[]]},{"id":"4cc7afbbcc802243","type":"mp4frag","z":"5273a6de.b59318","name":"","outputs":2,"basePath":"teste","serveHttp":"true","serveIo":"true","hlsPlaylistSize":"6","hlsPlaylistExtra":"2","autoStart":"false","preBuffer":1,"timeLimit":10000,"repeated":"false","statusData":"playlist","x":820,"y":300,"wires":[["652bde80360a1fe1"],[]]},{"id":"652bde80360a1fe1","type":"ui_mp4frag","z":"5273a6de.b59318","name":"","group":"46d6d60673638810","order":1,"width":22,"height":13,"readyPoster":"data:image/svg+xml;base64,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","errorPoster":"data:image/svg+xml;base64,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","hlsJsConfig":"{\"liveDurationInfinity\":true,\"liveBackBufferLength\":5,\"maxBufferLength\":10,\"manifestLoadingTimeOut\":1000,\"manifestLoadingMaxRetry\":10,\"manifestLoadingRetryDelay\":500}","autoplay":"true","unload":"true","threshold":0.1,"controls":"true","muted":"true","players":["socket.io","hls.js","hls","mp4"],"x":1010,"y":300,"wires":[[]]},{"id":"722408a8d61866db","type":"debug","z":"5273a6de.b59318","name":"debug 12","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":800,"y":360,"wires":[]},{"id":"d1112dfcbfef615b","type":"ui_button","z":"5273a6de.b59318","name":"","group":"46d6d60673638810","order":1,"width":0,"height":0,"passthru":false,"label":"Start","tooltip":"","color":"","bgcolor":"","className":"","icon":"","payload":"","payloadType":"str","topic":"topic","topicType":"msg","x":170,"y":300,"wires":[["c04f8845a87abbcd"]]},{"id":"2858e68578995d73","type":"ui_button","z":"5273a6de.b59318","name":"","group":"46d6d60673638810","order":1,"width":0,"height":0,"passthru":false,"label":"Stop","tooltip":"","color":"","bgcolor":"","className":"","icon":"","payload":"","payloadType":"str","topic":"topic","topicType":"msg","x":170,"y":340,"wires":[["379c223a6ef2f8ea"]]},{"id":"c04f8845a87abbcd","type":"change","z":"5273a6de.b59318","name":"","rules":[{"t":"set","p":"action","pt":"msg","to":"{\"command\":\"start\",\"args\":[\"-loglevel\",\"quiet\",\"-rtsp_transport\",\"tcp\",\"-i\",\"rtsp://belov:belov12345678@192.168.1.129:554/cam/realmonitor?channel=1&subtype=0\",\"-an\",\"-c:v\",\"copy\",\"-f\",\"mp4\",\"-movflags\",\"+frag_every_frame+empty_moov+default_base_moof\",\"-min_frag_duration\",\"1000000\",\"pipe:1\"]}","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":380,"y":300,"wires":[["7a8c3f95b486b8f9"]]},{"id":"379c223a6ef2f8ea","type":"change","z":"5273a6de.b59318","name":"","rules":[{"t":"set","p":"action","pt":"msg","to":"{\"command\":\"stop\",\"args\":[\"-loglevel\",\"quiet\",\"-rtsp_transport\",\"tcp\",\"-i\",\"rtsp://belov:belov12345678@192.168.1.129:554/cam/realmonitor?channel=1&subtype=0\",\"-an\",\"-c:v\",\"copy\",\"-f\",\"mp4\",\"-movflags\",\"+frag_every_frame+empty_moov+default_base_moof\",\"-min_frag_duration\",\"1000000\",\"pipe:1\"]}","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":380,"y":340,"wires":[["7a8c3f95b486b8f9"]]},{"id":"46d6d60673638810","type":"ui_group","name":"","tab":"9eb9a9fcd56859ba","order":1,"disp":true,"width":"22","collapse":false,"className":""},{"id":"9eb9a9fcd56859ba","type":"ui_tab","name":"Camera Mergulhador","icon":"dashboard","order":2,"disabled":false,"hidden":false}]
    "command": "stop",
    "args": [
        "-loglevel",
        "quiet",
        "-rtsp_transport",
        "tcp",
        "-i",
        "rtsp://user:pass@192.168.1.129:554/cam/realmonitor?channel=1&subtype=0",
        "-an",
        "-c:v",
        "copy",
        "-f",
        "mp4",
        "-movflags",
        "+frag_every_frame+empty_moov+default_base_moof",
        "-min_frag_duration",
        "1000000",
        "pipe:1"
