I stumbled on this Vue - Figma bridge:
And wondered if/how it could be implemented into UIBuilder.
Something like this could help, what do you think @TotallyInformation ?
At first sight, it looks as though it should be possible. Initial setup might be a bit fiddly but once you have the hang of it, it should be easy enough.
You will need to install figma-low-code into your uibuilder instance root folder I think. You will want a package.json file in that root folder.
I think though that you will probably need to also set up webpack or some other build process. You should arrange to have your source files in root/src and the built files in root/dist. Make sure you end up with an index.html in the dist folder otherwise uibuilder will continue to serve the one in the src folder.
Thank you very much.
I may try but my time and knowldege here is limited.
I'll accept it as solution.
If someone implement it, would you be kind to drop a line here?
