Hi Everyone, ![]()
May i know any others node can receive debug message to your smartphone other than telegram?
if i want to receive by using messages is it possible?
Hi Everyone, ![]()
For very basic Whatsapp communication take a look at 'whin'. Very easy to set-up and use.
Email is another option.
Thanks for reply ![]()
Or Pushbullet or Pushover or...
Are you using a snap install of node-red? If so is there a reason for that? I don't know whether it is part of the problem but it may well be. Are you able to try using the usual method of installing node red? If you are on a Debian based system (eg Ubuntu or Raspbian) you can use the install script at Running on Raspberry Pi : Node-RED
Actually i download node-red on window system, and i run the command using command prompt.
I've just tried the NR-flow I created some time ago.
The flow is on a RPi-4B running NR v2.1.3
Although it looks OK - the green dot, it doesn't send or receive text.
I suspect my token has expired. I've tried renewing it - doesn't change anything.
I'll try deleting and re-registering 'whin' (later) and see if that sorts out my issue.
I think your issue is something different.
What did you download?
i download node-red version2.2.2 on window.
Normally one does not download node-red, one installs it directly. Also that is an old version. What exactly did you download?
I recommend that you start again and install using the recommended method for windows. Running on Windows : Node-RED.
Then you will be running an up to date version and will have installed using a known method.
