How do i do a complete uninstall and reinstall of flexdash ?
I have removed all the widgets from the flow
in the manage pallete, i can see remove but when i click that i get an error message and the log shows only below
i tried renaming the folder in NR folder for flexdash - no effect
i deleted the folder and tried to remove flexdash - no effect
i restored the folder by an undo but now i think i have created a mess.
should i create a completely new NR folder and start from scratch ?
2022-12-27T09:58:55.221Z Remove : @flexdash/node-red-fd-corewidgets
2022-12-27T09:58:59.227Z Remove : @flexdash/node-red-flexdash
if i see install tab, it says already installed
i cant see any widgets on the left panel of NR editor
Have you also deleted Flexdash's configuration nodes?
Go to configuration nodes in the node-RED sidebar and delete any 'flexdash' containers, dashboards & tabs. Then try again.
Yes I have, there are no FD related config nodes on the panel
Go to the node-RED hamburger to right, select 'search flows', and search for flexdash.
Does it show any entries?
I get the following when i re-start Node-Red.
27 Dec 15:55:16 - [info]
Welcome to Node-RED
27 Dec 15:55:16 - [info] Node-RED version: v3.0.0
27 Dec 15:55:16 - [info] Node.js version: v16.16.0
27 Dec 15:55:16 - [info] Windows_NT 10.0.19044 x64 LE
27 Dec 15:55:18 - [info] Loading palette nodes
27 Dec 15:55:21 - [info] Dashboard version 3.2.3 started at /ui
27 Dec 15:55:22 - [warn] Missing node modules:
27 Dec 15:55:22 - [warn] - @flexdash/node-red-fd-corewidgets (0.4.61): fd-date-time
27 Dec 15:55:22 - [info] Removing modules from config
27 Dec 15:55:22 - [info] Settings file : c:\Users\OEEHo\.node-red3\settings.js
27 Dec 15:55:22 - [info] Context store : 'default' [module=memory]
27 Dec 15:55:22 - [info] User directory : c:\Users\OEEHo\.node-red3
27 Dec 15:55:22 - [warn] Projects disabled : editorTheme.projects.enabled=false
27 Dec 15:55:22 - [info] Flows file : c:\Users\OEEHo\.node-red3\flows.json
27 Dec 15:55:22 - [info] Server now running at http://127.0.0.1:1882/
Colin
27 December 2022 11:05
8
That is just a warning that you have removed them. What do you see if you restart again?
I am feeling Foolish now.
I swear, I have done restart before raising this issue. and it was still giving this problem, may be one node module was not removed properly ? (as seen in the above log).
Now it is OK after restart.
I have some issue in FlexDash Chart but will pursue in the already open thread for that issue.
thanks.
