Flow Programming UI, how to keep Groups Collapsed
As my program has grown, I collapse individual groups in the right sidebar in the Flow Programming UI, but when I "Deploy" They revert back to one widgit per line.
Is there a way to keep the right sidebar groups collapsed to one line per group except for the group you are working on? Currently at about 5 groups with up to 30-40 widgits per group.
Are you talking about the use of @flowfuse/node-red-dashboard, and in particular the dashboard tab in the right hand pane? So not groups in the node-red flow editor?
Thanks Colin, does this picture help to explain it? On the right I have collapsed "Data" and "Graphs" Groups, "Plugs" is still extended.
Where it gets tedious is when I am working on "Plugs" for example; after each "Deploy" when I come back to rearrange widgets say in "Plugs", I find "Data" and "Graphs" re-expanded.
Using Flow Fuse I believe, V 5.0.0 I am only about a month into this great program, so my vocabulary is not yet honed. As they say, a picture is worth 1000 words!
Yes, it is a pain. There are a couple of open issues on this, see below, but the problem is that there are apparently no flowfuse developers available to work on the dashboard, and not enough in the community helping, so nothing much is happening at the moment.
Thank you Colin! Will press forward! Thanks for reassuring me that I did not miss an obscure command in the documentation.
Cheers, Dave
