I am trying the code posted in Real-Time Data Chart with ChartJs Streaming - #2 by Mathieu.
But I get following error coming from app.min.js:
and the flow is shown below,
How could I solve these errors?
what's in the function node?
the function just returns the message payload.
msg.payload =
"data":msg.payload
I have not changed anything from the solution code posted in Real-Time Data Chart with ChartJs Streaming - #2 by Mathieu. I just imported it.
I have downloaded the javascripts files and put in the httpStatic folder.
<script src="/chart.min.js"></script>
<script src="/hammer.js"></script>
<script src="/chartjs-plugin-zoom.min.js"></script>
<script src="/chartjs-adapter-date-fns.bundle.min.js"></script>
<script src="/chartjs-plugin-streaming.js"></script>
Hello! Happy to see that someone found my flow !
could you share me your flow please ? When I posted my flow, I didn't fully understood what I did, but I get better in this so I think I can solve your issue ![]()
hi,
the post I shared had the flow but here it is again.
"id": "ebd7eeb0e4aac142",
"type": "tab",
"label": "test chart js stream",
"disabled": false,
"info": "",
"env": []
"id": "990aa6ae2bd4ca0e",
"type": "link in",
"z": "ebd7eeb0e4aac142",
"links": [
"3bfa2e543743a729"
"x": 195,
"y": 100,
"b920fde5f7ae96be"
"id": "5b059ced867507c5",
"type": "link in",
"links": [
"41a7afe3198738d3"
"x": 215,
"y": 160,
"id": "d7228ac3c969ee58",
"type": "ui_template",
"group": "16bc2f799e8aba9c",
"name": "Graphe Effondrement Electrode",
"order": 6,
"width": "17",
"height": "8",
"format": "<html>\n<body>\n<div>\n <button type=\"button\" id=\"resetZoom\">Reset Zoom and Pan</button>\n</div>\n<div ng-bind-html=\"msg.payload\"></div>\n<canvas id=\"streamingChart\" width=\"600\" height=\"400\"></canvas>\n<script src=\"/library/chart.min.js\"></script>\n<script src=\"/library/hammer.js\"></script>\n<script src=\"/library/chartjs-plugin-zoom.min.js\"></script>\n<script src=\"/library/chartjs-adapter-date-fns.bundle.min.js\"></script>\n<script src=\"/library/chartjs-plugin-streaming.js\"></script>\n\n<script>\n// the app in question keeps the last 5 minutes' worth of data in the buffer, the following should only apply to the rendered chart\nconst config = {\n minDuration: 5 * 1000,\n maxDuration: 1 * 60 * 1000,\n visible: 10 * 1000\n};\n\nconst streamingChart = new Chart($(\"#streamingChart\"), {\n // The type of chart we want to create\n type: 'line',\n \n // The data for our dataset\n data: {\n datasets: [{\n label: \"dataset 1\",\n data: []\n }]\n },\n \n // Configuration options go here\n options: {\n animation: {\n duration: 0\n },\n hover: {\n animationDuration: 0\n },\n responsiveAnimationDuration: 0,\n elements: {\n line: {\n tension: 0\n }\n },\n scales: {\n xAxes: {\n type: \"realtime\",\n streaming: {\n ttl: config.maxDuration,\n duration: config.visible\n },\n scaleLabel: {\n display: true,\n labelString: \"Time\"\n },\n display: true,\n time: {\n displayFormats: {\n millisecond: \"HH:mm:ss\",\n second: \"HH:mm:ss\",\n minute: \"HH:mm:ss\",\n hour: \"HH:mm:ss\"\n }\n }\n }\n },\n plugins: {\n zoom: {\n pan: {\n enabled: true,\n mode: 'x',\n rangeMin: {\n x: 0\n },\n rangeMax: {\n x: config.maxDuration\n }\n },\n zoom: {\n enabled: true,\n mode: 'x',\n rangeMin: {\n x: config.minDuration\n },\n rangeMax: {\n x: config.maxDuration\n }\n }\n }\n }\n }\n});\n\n$(document).ready(function() {\n $(\"#resetZoom\").on(\"click\", function() {\n streamingChart.resetZoom();\n });\n updateStreamingChartData();\n});\n\nfunction updateStreamingChartData() {\n streamingChart.data.datasets.forEach((set) => {\n set.data.push({\n x: Date.now(),\n y: bleh\n });\n });\n streamingChart.update();\n // NOTE: the device this chart is intended to stream data from actually sends a new point every 10 to 20 milliseconds, this 500ms delay is just to simplify this test...\n setTimeout(updateStreamingChartData, 500);\n}\n\nvar theScope = scope;\nvar bleh = null;\n\n// Watch the payload and update\n(function(scope) {\n scope.$watch('msg.payload', function(data) {\n update(data);\n });\n})(scope);\n\nfunction update(dta) {\n theScope.send({payload:dta});\n bleh = dta.data;\n otherStuff();\n}\n\n\n</script>\n</body>\n</html>",
"storeOutMessages": true,
"fwdInMessages": false,
"resendOnRefresh": true,
"templateScope": "local",
"className": "",
"x": 690,
"y": 80,
"id": "e5bfeff6.d88e2",
"type": "debug",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "true",
"targetType": "full",
"statusVal": "",
"statusType": "auto",
"x": 550,
"y": 140,
"id": "b920fde5f7ae96be",
"type": "function",
"func": "msg.payload = \n{\n \"data\":msg.payload\n}\nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 360,
"y": 100,
"e5bfeff6.d88e2",
"d7228ac3c969ee58"
"id": "f7a1760f8251aa08",
"type": "ui_spacer",
"name": "spacer",
"order": 1,
"width": 1,
"height": 1
"id": "16bc2f799e8aba9c",
"type": "ui_group",
"name": "Group 1",
"tab": "f4528104e64b1c48",
"order": 1,
"disp": true,
"width": "20",
"collapse": false,
"className": ""
"id": "f4528104e64b1c48",
"type": "ui_tab",
"name": "stream",
"icon": "dashboard",
"order": 11,
"disabled": false,
"hidden": false
Okay, can you share me the data you need to show please ?
On line 116 of the ui-template node there is:
Where is scope declared/set?
hmm, i just imported it and passed data used inject node. what is scope and where should it be declared or set?
