Hi guys,
I am trying to use the "context.get()" and "context.set()" in python3 function node and I am getting below error.
global name 'context' is not defined.
your kind help is much appreciated.
Thanks.
Hi guys,
Thanks.
What do you mean by 'python3 function node'?
can you provide your flow?
I assume you are using this node: https://flows.nodered.org/node/node-red-contrib-python3-function?
If so, it hasn't been updated in over a year - so will have fallen behind in what functionality it provides compared to the built-in Function node. There are a number of issues open against the node which suggests it isn't being actively maintained. You could try raising an issue, but otherwise, not much else we can do for you.
I must have had fumble fingers because when I searched the flows I didn't find any node with 'python3' - I'll bet I typed it wrong
