Flowforge plugin doesn't work.
I installed @flowforge/nr-tools-plugin and it can't find my FlowForge instance in the cloud. So I can make a snapshot.
The server has internet access and is connected to the account perfectly.
Are there any errors in the log?
Can I get you to raise an issue here: GitHub - flowforge/flowforge-nr-tools-plugin: A Node-RED Plugin that allows you to interact with a FlowForge platform from within your local Node-RED. and I'll investigate
I ask for some attention on the question of the support team related to the Flowforge product.
I really admire you and your work. And I'm trying to use flowforge cloud version with you and I always have difficulties.
Right now I'm going to test the delivery of the version with a cached version. I need this to work.
@allacmc I have recreated the issue locally. I'll update here when a fix is available, but it may be Monday or Tuesday before that is the case.
The plugin serves to facilitate the import.
I went there and did it by hand.
But it's good that the plugin works because I'm going to use it a lot.
I need to have local tests. And go up to the Flowforge.
That is a log from the device agent, which is not related to the nr-tools plugin.
I have identified the issue you are hitting. As I mentioned, I'll update here when a fix is available.
@allacmc we have just deployed a fix to FlowForge Cloud and confirmed the NR Tools Plugin is working again.
My apologies for the inconvenience.
I would like to thank you and say that I have already tested it here.
And it's working perfectly!
Congratulations to the Flowforge team, it's a 10.
The product is excellent and I highly recommend it to anyone who wants to build professional projects based on node-red.
It's working perfect!!
