FlowFuse 2.29: FlowFuse Expert Comes to Self-Hosted Enterprise
FlowFuse 2.29 is out.
Three things our enterprise customers have been asking for:
Use Azure DevOps as a Git provider in DevOps Pipelines.
Push and pull snapshots from Azure DevOps repositories, the same way you could with GitHub. Set up via Team Settings, Integrations.
Get FlowFuse Expert on your self-hosted enterprise deployment.
Until now, Expert was only on FlowFuse Cloud. Self-hosted enterprise customers can now have it enabled on their own infrastructure, with the same capabilities as cloud, while keeping operational data on-premise.
See exactly what changed when you compare two snapshots.
The compare dialog now has a property-level diff sidebar with line-by-line diffs of your function code, template HTML, and JSON. Step through every changed node with arrow keys. No more mentally diffing two function nodes side by side.
Less friction. More clarity. Built for the workflows you actually run.
Read what's new in 2.29: FlowFuse 2.29: FlowFuse Expert Comes to Self-Hosted Enterprise • FlowFuse
