need a cross domain iframe
which I think is usually done via the settings.js
"origin": "*",
"methods": "GET,PUT,POST,DELETE",
"optionsSuccessStatus": 204,
"headers": {
"Content-Security-Policy": "frame-ancestors 'self' https://example.com;"
what is the method in flow fuse?
Can I get a bump here - I wasn't having any issues with cross domain posting until I updated flow fuse now my forge rejects the iframe call
basically I have a chatbot distributed through a http node - that gives me the following error when embedded in an iframe @ forge.ai4socialservice.com refused to connect.
***note what IM trying to do is embed the http node link output html in a iframe not the editor
Any help with this appreciated
@BryanOgd as noted in the linked issue, a potential workaround is to edit your instance settings to modify the path the editor is served from. By default that is / - which causes its security policy to get applied to all requests. If you were to change that to, for example /editor, then the routes served by your node-red flows shouldn't get the security policy applied.
thanks I do have my editors at their own links. -- IFRAMED placement of http links generated by node-red works in my instal of flowfuse v2.1.0 and now not in v3.0.1
This brought up another issue as I vainly tried to effect the cross domain settings in my host with
Open the flowforge.yml file and ensure it allows embedding from your domain. Add or modify the following settings:
server:
# Other settings...
headers:
Content-Security-Policy: "frame-ancestors 'self' https://impactaiinc.com"
X-Frame-Options: "ALLOW-FROM https://impactaiinc.com"
# Other settings...
However when I tried docker compose up I got wacky ngnix 502 errors V3.0.1
So I just saved the flows and reinstalled the whole flowfuse and now Im scared to even touch flowforge.yml or really even restart the flowfuse at all - but this still leaves me without a chatbot embedded in another off domain webpage
I saw a recent 502 errors post that required an update --
