Format Buffer to HexString in function node
Hi all,
I need to do a rather simple task. I would like to format this Buffer:
var char = Buffer.from([0x7e, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xff, 0xef])
in a function node (or any other way) as a HexString:
var str = "7e000000000000ffef"
To be able to send this hex stream via gatttool to bluetooth client.
Unfortunately I got completely stuck. Could you please help me ?
Hello .. you can try .. .toString("hex")
msg.payload = char.toString("hex")
Result:
.. alternatively you can use the node-red-contrib-buffer-parser node
with these settings
that should give you the same result
Hello !
It works. Nice and easy ! Thanks a lot.
